RaceDayQuads has a nice looking 300W power supply available. It's compact and plug and play for chargers that use XT60 connectors for input power like iSDT chargers. Of course you could always replace the XT60 with a connector of your choice to power anything that needs a 12V source. It can put out 300W of power at 12V at a maximum of 25A. That should cover the majority of your charging needs.
The power supply size is listed at 230x64x35mm, it has overload protection, overtemp protection, short protection and best of all, carries a 3 year manufacturer warranty. The price is $39.99, so if you are in need of an affordable compact power supply for your chargers, you'll want to check this one out.
Thread Tools |
Yikes!
![]() Never mind the fact that the supply with screw terminals and no strain relief on the input and output and is an internal chassis mounted supply that is not type designated as it's being presented and sold. I'd personally avoid this particular supply given the fact that the non-strain relieved mains input is potentially hazardous. |
ISDT chargers really want 24 volts.
I'm astonished anyone would sell that supplied with the mains power cord shown. All sorts of potential liability issues when a wire comes loose.
Latest blog entry: Eachine QX65 FPV quad review
Hi,
It for sure should not be marked with a CE marking to be sold here in Europe with that exposed cords in both ends. It is hard to understand why any company would like to sell a power supply with this obviously dangerous design to hobbyist or any other consumer. This power supply has a label on the side marked with both CE and FCC. I can not understand how it can conform to any basic safety with the design it has. It is obviously not a power supply intended to be sold to consumers or hobbyists to be used as it is, it seems to be designed to be built in or not be in reach easily for any person. /Bo |
The "server" power supplies that many buy are also not made to be used stand alone and some have the same exposed terminals so why is everyone concerned about these? Yes you have to be careful with the wiring but that goes with any charging system.
I'm not a lawyer but AFAIK if you buy a bare power supply and fit cables yourself then you are responsible for the consequences. Buying one with a lead and mains plug already on it is a bit different - if it's unsafe then the manufacturer/vendor is potentially liable.
We all should be responsible for how we set up and use our charging equipment. I see this as no big deal. The reason we use server supplies is that they are cheap. These are the same kind of deal IMO.
As mentioned, components like server power supplies would generally be sold 'bare' as they're intended to be built into a case/cabinet rather than used straight out of the box. If someone decides to hook one up direct to the mains supply with exposed terminals etc. then that's at their own risk. |
Thread Tools | |
Similar Threads | |||||
Discussion | Power Supply +12V@4.5A or +5V@25A | basicguy | Batteries and Chargers | 4 | Dec 27, 2015 12:49 PM |
Discussion | Turnigy Reaktor 2 x 300W 20A Balance Charger Power Supply? | Brayden1202 | Batteries and Chargers | 13 | Dec 16, 2015 03:45 AM |
Discussion | Smallest/Lightest 12v 15-25A Power Supply | RCnGuy | Batteries and Chargers | 19 | Oct 02, 2012 02:50 PM |
new radio shack power supply 12v 25A | dalbert02 | Batteries and Chargers | 24 | Aug 30, 2003 12:52 AM |
