Jul 16, 2018, 07:07 PM
crawf56's Avatar
Ok, rather build the fuselage over the plans at the start, I thought it might be better to assemble the fuselage sides and formers, and then place it OVER the plan.
I started by attaching formers F4 & F5 to one of the fuselage sides F1/F2. Used a small 90 degree triangle to make sure F4 & F5 were perpendicular.
Then I attached the other side F1/F2 to assembly. This was placed over he F6/F3/F7 assembly (bottom of the fuselage).
Jul 16, 2018, 07:10 PM
crawf56's Avatar
The rear fuselage sides were pinned in place and glued. Once that was done, I held the top of the fuselage to what seemed right, and glued the rear 1/8" dia. dowel.
Jul 16, 2018, 07:12 PM
crawf56's Avatar
And just for fun: Here is the fuselage to my Balsa-USA 1/3 scale Nieuport 28, with my Eugley Stick fuselage in the foreground.
NOTE: Manzano Laser Works was nice enough to make me a plywood F10 firewall. THANKS!!
Jul 16, 2018, 08:31 PM
crawf56's Avatar
Moving along, I have decided to do more of a DNU tail that the Eugley tail. In other words, more slab, less stick.
Here is the rudder/fin. Still not sure if I will do a functional rudder.
Jul 16, 2018, 08:41 PM
crawf56's Avatar
Here is my balsa list for the wing & fuselage:
1/16" x 1/4" x 36"
3/32" x 1/4" x 36"
3/32" x 2" x 12" need 2
1/8" x 1/8" x 36" need 3
1/8" x 3/16" x 36"
3/16" x 1/4" x 36"
1/4" x 3/8" x 36"
1/4" x 1/2" x 36"
Jul 17, 2018, 11:31 PM
crawf56's Avatar
OK. Not such thing as too much balsa.
Jul 17, 2018, 11:33 PM
crawf56's Avatar
More work on the fuselage. With 1/8"x1/8" balsa and triangle stock.
Jul 18, 2018, 10:21 PM
crawf56's Avatar
OK, let's talk about engines. I have a few choices.
What arrived today is an .049 with throttle control (of a sort) from Ex Model Engines. This is my 'lead candidate'.
Jul 18, 2018, 10:24 PM
crawf56's Avatar
Next option is a Norvel-ish engine that I got around 10 years ago. It runs, sounds good. But has no throttle control. Even if I don't put this on first, it will see time on my Eugley Stick at some point.
This engine is currently on my Electra (Gentle Lady).
Jul 18, 2018, 10:27 PM
crawf56's Avatar
Last but not least is my Cox Cobra free flight helicopter. There's the .049 on top. I have thought about removing the engine, but I can't quite make myself do it. Not really an option. (Unless I change my mind.)
Jul 19, 2018, 01:45 AM
Nitro User
1/2A Nut's Avatar
Here you go Craw you can add a RC carb to your Norvel
Looks like you have a Big Mig version the Norvel will provide
some good flying for the plane. They ship from the US and it
happens fast.
http://www.nvengines.com/index.php?p...mart&Itemid=65
Jul 19, 2018, 10:10 PM
crawf56's Avatar
Yeah, think I am going to get that carb, Amp Abuser. Thanks.
Jul 20, 2018, 04:53 PM
Hey Crawf56,
You and I may have something in common! We both have a Norvel .061, but don't want to the existing intake!
I fly CL...I picked up a carb'd BigMig. Care to swap carb for Venturi?
Jul 20, 2018, 11:20 PM
crawf56's Avatar
Originally Posted by 944_jim
Hey Crawf56,
Sounds good. Sent you a private message.
Jul 21, 2018, 12:01 AM
WooHoo! Gotta love the Internet!
Pics in the AM.
Thx
Discussion Pat Tritle / Manzano Laser 44" Tiger Moth build danielraible Scale Kit/Scratch Built 136 Oct 07, 2018 12:02 AM
Build Log Pat Tritle Pietenpol 48": My first scratch build from plans sheakspear Balsa Builders 28 Aug 03, 2018 04:55 PM
Build Log Cox Cobra 1/2A Free Flight Heli from Arkansas crawf56 1/2A Planes 77 May 01, 2017 11:57 PM
Build Log Pat Tritle Shoestring - Stick frame and brushless power philipa_240sx Scale Kit/Scratch Built 39 Sep 05, 2013 09:53 AM
