Jul 13, 2018, 12:43 AM
foxtechtech's Avatar
Tutorial Material Summary for Foxtech Nimbus Mapping VTOL
Foxtech Nimbus Mapping VTOL Combo has been proved to be a mature tool for mapping jobs.
There are some technical updates and tutorial videos, manuals released day by day as Foxtech works hard on it everyday.
Hereby We post all material here, and wish more feedback and communication shared with all interested in this.
Latest blog entry: FOXTECH GAIA 120 Hexacopter
Jul 13, 2018, 12:45 AM
The Nimbus Mapping version is equipped with new landing gears. The foldable tail landing gear and front landing gear. The front landing gear ensure enough space for mapping cameras or zoom cameras, and will protect the loading equipments. Also the quick-detached design makes Nimbus VTOL easy to install and transport.
And the power system is also upgraded. The front motor is changed to Foxtech 3520 kv520, which is more powerful, the new power system has great power redundency, and makes the mapping version more efficient, which can lift 500g without any problems. The max flying speed is up to 35m/s.
The battery compartment is big enough to hold one 6S 10000mAh lipo battery, with one 6S 10000mAh lipo battery the duration is around 1 hour including take-off and landing.
As for our Map-01 mapping camera, it can take 24.3 MP pixels photoes. You can simply change the camera's lens according to your needs. And the compatible lens including E35mm, E20mm, E25mm. And Nimbus VTOL equipped with this mapping camera can cover an area of 1-2 square kilometre depending on the resolution your needed. In order to increase the map precision, also could add a high precision GPS module, which is linked to PPK system, so the mapping camera can take photoes at a centimetre-level.
The Nimbus Mapping version is equipped with a 15km Range Datalink(900MHz) for long range inspection. Foxtech Nimbus 1800 VTOL mapping version is cost-effective plane compared with other expensive multicopters or fixedwings, it is a good option for customers to do mapping jobs.
Specifications:
Version: VTOL Mapping Version
Material: EPO
Wingspan: 1800mm
Length: 1300mm
Max Flying Height: 3500m
Max Flying Speed: 35m/s
Take-off Weight: 2.85kg(without battery)
Suggested Take-off Weight: 4.8kg
Suggested Payload: 500g
Suggested Battery: 6S 10000mah Lipo Battery (x1), 6S 9500mah Li-ion Battery (x2)
Features:
-Take off and land vertically like a multicopter.
-Fly fast as a fixed wing, while it’s doing so, the tail motor stop spinning.The max speed is beyond 25m/s.
-Go waypoints & click-go automatically in either fixed wing or multicopter mode.
-No launching rail or parachute needed, launching directly from an area as small as 4x4m
-Do mapping jobs by designing in ground station.
-In case there is any failure on ailerons, elevators, Nimbus VTOL mapping version can switch to multicotper mode to save the plane.
Discussion Nimbus 1800 Tilt VTOL JohnVH FPV Aircraft 244 Jan 14, 2021 08:32 PM
News Wingtra One PPK VTOL for Aerial Mapping Jason Cole Commercial UAV/FPV 8 Jul 24, 2019 02:56 PM
Discussion Nimbus 1800 Vectored Yaw VTOL ! Tricopter Long Range Vtol available! foxtechtech VTOLs 56 Aug 05, 2018 07:17 AM
New Product Foxtech Nimbus 1800 VTOL Mapping Version Released foxtechtech FPV Aircraft 1 Jun 05, 2018 07:52 AM
News Foxtech Map-01 Aerial Mapping Camera Jason Cole Commercial UAV/FPV 0 Apr 23, 2018 08:46 AM
