This thread is privately moderated by patniven, who may elect to delete unwanted replies.
Jul 12, 2018, 09:34 AM
Trader Rating: 26
Gus Grissom: "F***in-A bubba!"
patniven's Avatar
$299.00 USD
Seller Pays Shipping
Sold
OS Engines GGT-10 - Gasoline Engine - NIB
For sale is a NIB OS GGT-10 gasoline engine with muffler and 2 extra ignition plugs.
This engine retails for $320 on Tower, but has been unavailable for some time.
Shipping is FREE in CONUS
Call, text or email: patniven@bellsouth.net (PayPal address) 850-206-7407
FEATURES
Glow plug ignition for easy starting and elimination of ignition
modules and batteries
Ideal for .40 size aircraft
Same mounting dimensions as the O.S. Engines .46AX and .55AX
Runs on an inexpensive 50:1 gasoline/oil blend
PD-08 pump regulates fuel flow for consistent delivery, Tygon fuel
tubing between pump and carburetor with in-line fuel filter
PowerBoost Pipe improves performance at all points from idle to full-
throttle
Forged steel connecting rod with needle bearings in crankshaft hole
Two year limited warranty through Hobby Services beginning at date
of purchase.
INCLUDES
GGT10 10cc Gasoline Engine
E-3071 PowerBoost Pipe
M3x35mm Socket Head Cap Screws for mounting muffler
Two 3mm Locknuts
G5 Gasoline Glow Plug
Drive Hub, Prop Nut, Washer and Instructions
REQUIREMENTS
Unleaded gasoline, 2-stroke oil
Propeller: (Recommended sizes include: 12x7, 12x8, 12x9, 13x6,
13x6, 13x7 and 13x8)
Glow starter & field equipment
SPECIFICATIONS
Displacement: .61 cu in (10 cc)
Bore: 0.945 in (24.0 mm)
Stroke: 0.846 in (21.5 mm)
RPM Range: 2,000 - 11,000
Output: 1.58 hp @ 10,000 rpm
Total Weight: 19.8 oz (561 g)
Engine Weight: 15.97 oz (453 g)
Muffler Weight: 3.81 oz (108 g)
Distance between Mounting Hole Centers Same Side: 0.69" (17.5mm)
Distance between Mounting Hole Centers Opposite Side: 1.7" (44mm)
Width at Mounting Tabs: 2.0" (51mm)
Width of Crankcase below Mounting Tabs: 1.4" (36mm)
Length from Crankcase Center to Exhaust Outlet: 3.9" (101.3mm)
Height/bottom of Mounting Tabs to Muffler Bottom: 1.24" (31.7mm)
Height/bottom of Mounting Tabs to Top of Cylinder Head: 2.8" (72mm)
Height/bottom of Crankcase to Top of Cylinder Head: 3.5" (89.8mm)
Length/Crankcase Center to Drive Washer: 2.7" (69.1mm)
Length/Crankcase Center to end of Crankshaft: 3.34" (85mm)
Length from Pump to end of Crankshaft: 5.1" (130mm)
Crankshaft Size: UNF 1/4-28
Muffler Angle Relative to Engine: 4
Sold OS GGT 10 Gas engine joedoan Aircraft - Fuel - Engines and Accessories (FS/W) 3 Dec 20, 2017 06:05 PM
Sold OS GGT-15 Gasoline Engine for .60 size Airplanes patniven Aircraft - Fuel - Engines and Accessories (FS/W) 0 Dec 17, 2017 12:19 PM
For Sale looking for Os engine GGT 10 pperes1 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Nov 01, 2017 11:52 AM
Sold OS GGT-10 Gas Motor Combo NIB PRICE REDUCED gbr677 Aircraft - Fuel - Engines and Accessories (FS/W) 2 Oct 24, 2017 07:53 AM
Sold New OS GGT 10 cc Gasoline engine squirrel40 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 25, 2016 01:37 PM
