Dle-55ra - nib - RC Groups
This thread is privately moderated by patniven, who may elect to delete unwanted replies.
Jul 12, 2018, 07:57 AM
Trader Rating: 26
Gus Grissom: "F***in-A bubba!"
patniven's Avatar
$375.00 USD
Seller Pays Shipping
Sold
Dle-55ra - nib
For sale is a brand new-in-box DLE-55RA, still sealed in the factory box. This engine retails for $420 on Tower, but is currently not available.
Shipping is FREE in CONUS.
Call, text or email: patniven@bellsouth.net (PayPal address) 850-206-7407
FEATURES
High performance in a compact package
Rear exhaust for the perfect tuned pipe setup
Pitts style aluminum muffler
Newly designed piston with re-engineered skirt for less piston
weight resulting in such advantages as awesome throttle response,
more power and longer engine life
Electronic ignition is the no-hassle answer to simpler starts,
higher performance and minimal RF noise
Producing 100 more rpm than the DLE50, the DLE 55-RA comes with
engine standoffs, electronic ignition, spark plug and muffler
Two year limited warranty through Hobby Services beginning at date
of purchase
INCLUDES
DLE 55-RA Gasoline Engine
Electronic Ignition
Pitts Muffler
DLE CM6 Spark Plug
Four Engine Standoffs with Mounting Hardware
Integrated Choke Rod Guide
Rear-mounted Carb
Instruction Manual
REQUIREMENTS
Gasoline with at least 87 octane rating
2-cycle oil, mix ratio for this engine is 30 parts gas to one part
oil and must be followed exactly for warranty consideration
and optimum performance
4.8 - 12V battery for ignition
(separate receiver style pack can be used) (LiPo & LiFe requires
voltage regulator)
Propeller and field equipment
SPECIFICATIONS
Displacement: 55.6 cc (3.39 cu in)
Bore: 1.76 in (45 mm)
Stroke: 1.37" (35mm)
Compression Ratio: 7.6:1
Static Thrust: 14.5kg Pulling Force/100 meters altitude
12.8kg Pulling Force/1,800 meters altitude
Gasoline/Oil Mixture: 30:1
Gasoline Octane Rating: 87
Recommended Propellers: 22x8, 22x10, 23x8, 23x10
Weight, engine: 3.74 lb (1.33kg)
Weight, muffler: 3.17 oz (90 g)
Weight, ignition module: 5.11 oz (145 g)
Output: 5.5 hp @ 8,500 RPM
Carburetor Adjustments;
Low Speed Needle: 1.5 turns out as a starting point, adjust for a
smooth idle and a reliable transition to high throttle
High Speed Needle: 1.5 turns out from closed, adjust needle to peak
RPM, if engine slows or dies at full throttle, the high-speed
mixture is likely too lean
Muffler Dimensions: 3.8 x 2.6 x 1.2" (97 x 66 x 31mm)
Muffler Exhaust Outlet Diameter: 0.79" (20mm)
Muffler Exhaust Outlet Length: 0.79" (20mm)
Length from end of each Standoff to Prop Hub: 6.7" (171mm)
Distance Between Mounting Hole Centers Same Side: 2.6" (67mm)
Distance Between Mounting Hole Centers Opposite Side: 3.5" (90mm)
Height from bottom/Crankcase to top of Cylinder Head: 5.9" (150mm)
Width of Cylinder Head: 3.1" (80mm)
Distance Between Muffler Mounting Hole Centers: 1.7" (43mm)
Crankshaft Thread: 5mm/.8 pitch course thread
Found Looking for a DLE 55, not a DLE 55RA MarkU1967 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Aug 29, 2017 11:19 AM
For Sale NIB DLE 55ra mx_ata2d Aircraft - Fuel - Engines and Accessories (FS/W) 1 Feb 18, 2017 05:33 PM
Sold NIB DLE 55RA never seen Fuel Scale330l Aircraft - Fuel - Engines and Accessories (FS/W) 0 Mar 31, 2015 10:44 PM
Sold Dle 55ra nib Farmflyer01 Aircraft - Fuel - Engines and Accessories (FS/W) 1 Jan 23, 2015 10:43 PM
Sold DLE 55Ra Bennett muffler NIB doomking Aircraft - Fuel - Engines and Accessories (FS/W) 0 Apr 22, 2014 06:46 PM
