150% Avro Vulcan - RC Groups
Jul 11, 2018, 08:10 AM
Multirotor Enthusiast
Blacky's Boy's Avatar
Build Log
150% Avro Vulcan
OK, so I decided to document my build of a 150% Avro Vulcan as first shown by BHOFM in this thread:
https://www.rcgroups.com/forums/show...oam-delta-wing
As I progress through the build I'll document it here.
Lets start with the plans.......
In that thread there was a link to the article and PDF Plans for the 1.0x version. I just imported that PDF into Autocad and then traced over top of it. Once that was done I scaled it up by 1.5x and BOOM, 150% bigger! While I was at it I used the information from this thread
Prop Slot Noise Reduction Design and Tests
to make the cut out for the prop. This will help it to be quieter and somewhat more efficient. I made a PDF of the drawing sheets and hopefully that will help others who try to make this model
Using those plans I made templates and cut out the parts last night. I gotta' say, it's a lot bigger in "real life". This is going to be a HUGE plane.
I'll start the initial glue up tonight and post photos as soon as I can
Jul 11, 2018, 01:06 PM
An itch?. Scratch build.
eflightray's Avatar
Wow! 150% Vulcan.
The B.3 was 120 foot span, that makes it 180 foot span. I hope you have plenty of foam.
Though I suppose you mean 150% of the 29 inch foamie. Shame, would have been impressive.
Jul 11, 2018, 06:25 PM
Kimbers Keeper.
BHOFM's Avatar
I just set my Brothers Monochrome laser printer to 150% and pushed "print"!
It is a nice size plane!
Jul 11, 2018, 07:32 PM
Well,....that's certainly one (easier) way to get the job done.
I really wanted to actually scale it so I could lay out the parts and see how many sheets of 24" x 48" MPF it would take. And that number is (2).
Jul 15, 2018, 08:22 PM
Some progress
OK, the main parts are joined and you can see where I added the spars as well as some bbq skewers to the LE to help make the wing a bit stiffer. The pair of cf rods on the main wing that go back under the vert stab are there to help stiffen the back. It was an area on the small scale version I have that was always too flimsy for my tastes. I also added a strip of foam at the vert stab to help give it a bit more support.
I just need to install the rudder and elevons then it's onto the firewall and support structure. I want to back up that foam where the firewall is glued with some EPP. When building my Divinity 2 I found that this gives me a nice solid motor mount without going overboard on the weight. After all that is done I will install the electronics
It's still super light for it's size and I think I'm going to leave off any coloring (with tape) or keep it to an absolute minimum until I can maiden it and see how it performs.
Jul 16, 2018, 03:35 AM
eflightray's Avatar
There is always the 'old fashioned' method, a scaling pantograph.
That way you could even scale up and draw it directly onto the material. Though something the size of a wing could be a bit tricky, it's ideal for formers, ribs etc.
Jul 16, 2018, 06:36 AM
I've used Pantograghs before but would much rather use CAD to scale up a drawing to the exact size I want and then easily manipulate (rotate, mirror, and move) the geometry to fit on a sheet.
28 years of using Autocad make that just how I roll.
Build Log Avro Vulcan in foam board from Model Aviation DuPageJoe Foamies (Scratchbuilt) 36 May 24, 2017 07:16 PM
Build Log Avro Vulcan b2 holiday project nickchud Foamies (Scratchbuilt) 6 Feb 04, 2017 04:09 PM
Discussion A Giant Scale Jet Worth Seeing 1/5 Scale Avro Vulcan Chophop Fuel Plane Talk 0 Jan 26, 2017 10:36 AM
