Jul 09, 2018, 07:33 AM
Free Flight rubber flyer
jwfinn's Avatar
DLG exercise
This is my latest strategy for staying skinny.
F3K/Discus Launch Glider quick turn marathon! (2 min 57 sec)
Any of the rest of ya'll do silly stuff like this?
Jul 09, 2018, 11:45 PM
New at this whole life thing
Cfiimei's Avatar
Looks like arm-powered DS!
Jul 10, 2018, 12:06 PM
a.k.a. Bob Parks
Where it is that flat , it is the only way to do DS! (except the trees)
BP
Jul 11, 2018, 10:57 AM
jwfinn's Avatar
BP
Yeah, tried DSing trees a few times. Apparently not my forte. And an expensive way to learn that.
Jul 11, 2018, 09:38 PM
As long as we're talking DLG exercise, there's a way to practice in a modest sized back yard. It won't do much for your technique, but it ought to help with the conditioning. Securely mount some small weights on diagonally opposite corners of a long, thin board. I used a piece from a cedar closet kit. Hold the board with the weight at the tip forward, and DLG it. The moment it's released, the board will start to spin and, if it's nice and light, it won't go very far at all. Maybe 30 feet, depending on the weight and the force you launch with. Suggest trying this out at the field first, in case something isn't exactly symmetrical. It's important to make SURE both weights are securely fastened. If just one comes off, the board may become stable and go as far as the nearest window. (Or, at least, that's my theory, haven't tried it yet.) You can leave off the weights, but then the board will try to twist out of your hand.
Discussion Techone DLG-1000 (EPO DLG) 8thelephant Hand Launch 266 Dec 08, 2018 05:45 AM
Build Log Aires Series of Micro DLG's Design and Development (Very Small DLG) RobertTHaas Hand Launch 333 May 27, 2016 08:23 PM
Discussion DLG's and Drag or lets design the ideal DLG wing shape and location Chuchuf Hand Launch 95 Apr 20, 2016 04:19 PM
Build Log THERMALPLEX DLG - Design, Build, Test, Optimize, Produce, a Flying Wing DLG... RobertTHaas Hand Launch 254 Dec 31, 2015 07:42 PM
Discussion 1st glider, HK Mini DLG vs Mini DLG Pro... Jimmy JFlyer Hand Launch 3 Dec 26, 2015 06:44 PM
