Vector tuning for throttle curves and expo - RC Groups
Jul 06, 2018, 01:09 AM
Hi - what is the right right way to set-up throttle curves or expo when using the vector? Do you do this through the tx and then run the rx wizard for the vector to measure the limits or do you setup the tx with the tx defaults and then tune everything through the vector? My specific aim is to tune my throttle control as it seems to be very quick to reach a limit where there's no further power increase. I also want to increase my expo on the ailerons to smooth out the roll. Thanks, Neal
Jul 09, 2018, 08:07 AM
JohnET's Avatar
Hello,
It sounds like you need to calibrate your ESC(s) instead of creating a curve. After doing that, re-run the RX Wizard. Otherwise, in general as long as you have your control surfaces setup correctly and have your ESCs calibrated, you do not need any curves when using the Vector. if you feel you do need a curve, re-run the RX Wizard after setting the curves.
Regards, John
Jul 10, 2018, 01:29 AM
Thanks for the reply, I'll calibrate the ESC and try it.
