This thread is privately moderated by mwhidden, who may elect to delete unwanted replies.
Jul 05, 2018, 11:12 AM
MA, USA
Build Log
Mark's Models Wanderer (1976 Balsa Glider Kit) - Part 5
I applied the epoxy-embedded fiberglass reinforcement to the center wing joint and the wing tip joints, and also small patches on the trailing edges to prevent the rubber bands from damaging the edge. I think it turned out functionally, but not pretty, and I'm sure it won't look so hot through the Monokote.
After the photos below, I did apply a 2nd "skim coat" of epoxy to the middle to smooth out the checkerboard texture of the fiberglass that was still showing through.
Horizontal stabilizer and elevator construction is underway. I'm a bit stumped about the best way to taper the elevator surface. It should run from full thickness at the leading edge to about 1/32" at the trailing edge. I'm not sure if I'll hand-sand it to the right taper, or if I'll build some sort of jig to keep a sanding block at the right angle. I read that some put a 1/32" wire against the trailing edge to stop the sanding block from taking too much off that end.
Any ideas are welcome.
Discussion Mark's Models Wander 72 bolt on wing? deadstickdan Sailplane Talk 10 Nov 02, 2015 01:10 AM
