Jul 12, 2018, 07:27 PM
Woga65's Avatar
Originally Posted by jt41time
Did u run big blades on the last quad? Will the tail blade holders hold up to that amount of force? I'm assuming those are 325 or something close.....
It is 280 mm blades, the blade holders are 500 size.
Jul 12, 2018, 07:53 PM
Just call me Justin.
Cool.
I wanted to do 600 tail and a 450 dfc head with 600 slider. I think, if I can remember that long ago, the 600 nitro tail had the same 5mm tail shafts as a 450 main shaft.
Plz pull this off. I so want to build a monster after I know this one will work. Or even a tiny one. Use 250 gear... one big motor. But hey, I just love dif stuff. I'm sick of the normal things we got out there.thank you for hitting this hard...
Jul 13, 2018, 03:28 AM
Wake up, feel pulse, be happy!
Piece's Avatar
Man, you weren't kidding around about wanting a quad with the maneuverability of a conventional heli.
This is very cool. What do you do for a beast like this in terms of flight control? Flat throttle, variable pitch control only? Or is there an element of motor control in addition to the VP system (e.g. for yaw authority)?
Latest blog entry: Jeti ESC resto-mod
Jul 13, 2018, 05:20 AM
Woga65's Avatar
For the first there will be flat throttle, next I will have to find either a proper pitch curve or use the govervor mode. Not sure if governor mode works with four single motors since the governors may influence each other.
A throttle control would be an option for the tail rotors.
Jul 13, 2018, 05:16 PM
Woga65's Avatar
I decided to go with stronger servos and proper servo mounts.
Jul 13, 2018, 07:18 PM
Hurry up and get thing in the air. Jeez.....
Hehhehehehe
Have you spun up the mains yet?
Jul 13, 2018, 07:21 PM
I was thinking about the whole pid problem with varying in rotor speed. Isn't there a couple "profiles" that you can switch between on the fly in betaflight? If so, can u have a couple dif profiles on a three way switch that also does a dif throttle curve for each. Kinda like a idle up on crack.
Jul 13, 2018, 07:23 PM
Or even a lua script in your taranis? A linear pid curve per throttle curve...
Jul 14, 2018, 04:34 AM
Woga65's Avatar
... Have you spun up the mains yet?
I spun up the mains after gluing in the bearings but this was without rotors so things remain exiting!
The PID are not problematic. There will be three sets of PIDs, one each for low, mid and high head speed.
I also made a custom version of betaflight with a few extra lines of code that vary the PID depending on the head speed, but this is experimental.
I do not own a taranis, just a Spektrum DX7s, an old Futaba FX18 and a DEVO 10 with DEVIATION TX on it.
Jul 14, 2018, 01:21 PM
Woga65's Avatar
Frame and mechanics finished, now it is time to add the electronics.
Jul 14, 2018, 01:28 PM
Looks massive.
Are those plastic blade holders on the rears?
Jul 14, 2018, 01:49 PM
Woga65's Avatar
Looks massive.
Yes they are. The plastic rears provide some basic dampening.
Jul 15, 2018, 01:46 AM
géry 46's Avatar
Nice ship Woga 65....
it's seem that your accelerometer (gyro) will be not placed in the cross of your four prop axis..??
Jul 15, 2018, 05:15 AM
Woga65's Avatar
Thank you!
The gyro measures angular speeds so it does not matter where it is mounted as long as it points to the correct axis.
The accelerometer measures linear acceleration so in theory it does matter, but since it is just used to estimate the direction of gravity it does not matter too.
Jul 15, 2018, 10:12 AM
Rumcajs's Avatar
I'm sorry, I'm using a translator
And you thought about one engine, something like here?
Discussion Betaflight - variable pitch quad - dynamic PID setup Woga65 Multirotor Drone Electronics 0 Dec 08, 2017 07:11 PM
Discussion Gas powered variable pitch quad dll932 Life, The Universe, and Politics 11 Mar 03, 2017 03:51 PM
Discussion The V-Pitch Variable Pitch Prop motor...quad? docinfrance Multirotor Drone Talk 33 May 11, 2012 05:36 PM
New Product You thought you had a cool quad...new variable pitch prop quad!! Bigcats30 Multirotor Drone Talk 3 Feb 28, 2012 05:22 PM
Discussion a variable pitch, one motor, micro quad? robZulu Multirotor Drone Talk 31 Feb 04, 2010 07:58 AM
