Jun 23, 2019, 12:57 AM
Woga65's Avatar
Originally Posted by RCvertt
That hair pin is a good trick. Are you using an accel on this latest build or gyros only?
Until now gyro only. In the near future i will use gps assisted modes.
Since it basically works in F i am porting it to iNav right now.
Jul 20, 2019, 07:03 PM
Woga65's Avatar
The last few weeks i did not feel like looking for a quiet place to test the helicopter. To be honest after it is basically working it is just half that interesting to me.
So for now i grabbed the variable pitch quad from the beginning of this thread and started to clean up the messy cabling.
Also i got rid of the unneeded central motor mounts that were used for the belt-drive.
The saved weight will give room for a decent battery mount and perhaps for a higher landing gear.
Jul 21, 2019, 11:37 AM
Woga65's Avatar
Call it Mr. Long Nose
Its done!
By cleaning up the wiring and removing unneeded parts i could save approximately 50 g to 60 g.
Adding a battery tray added some grams but it is still lighter than before.
Dry weight: 1483 g
Weight including a 6s 2700 mAh lipo: 1851 g
Jul 25, 2019, 12:10 AM
RCvertt's Avatar
That sounds like a great port. Looking forward to watching your build
It‘s done!
Dry weight: 1483 g
Great job on the build and the weight savings. With the weight savings it can carry a camera now for free.
Aug 08, 2019, 07:24 AM
Woga65's Avatar
After the small one successfully moved to iNAV i also mounted a GPS to the big one which added 33 g to her weight. Since it is far away from any high current source i am using the built in magnetometer of the FC.
Video of the small one:
Chinook style Bicopter with INAV (1 min 14 sec)
Discussion Betaflight - variable pitch quad - dynamic PID setup Woga65 Multirotor Drone Electronics 0 Dec 08, 2017 07:11 PM
Discussion Gas powered variable pitch quad dll932 Life, The Universe, and Politics 11 Mar 03, 2017 03:51 PM
Discussion The V-Pitch Variable Pitch Prop motor...quad? docinfrance Multirotor Drone Talk 33 May 11, 2012 05:36 PM
New Product You thought you had a cool quad...new variable pitch prop quad!! Bigcats30 Multirotor Drone Talk 3 Feb 28, 2012 05:22 PM
Discussion a variable pitch, one motor, micro quad? robZulu Multirotor Drone Talk 31 Feb 04, 2010 07:58 AM
