| Thread Tools |
| This thread is privately moderated by RightBrother, who may elect to delete unwanted replies. |
EPP scratchbuilt Delta wing
Couple more photos of my delta wing. Learned a couple of lessons. Bottom is perfectly flat so next time might use symmetrical shape. See how this one flies. Might use some sort of software to design ribs but that is too work intensive for me. Probably use a single center fuse rather than two.
Strapping tape ironed on seems t adhere to epp ok, if not then will use hinges for elevons. Made motor mount from couple layers of 3mm plywood. Want to be able to dismount motor mount easily. Plastic motor mount will be bolted to plywood. Elevons are very rigid. Used a carbon rod and laminated them. Not too much more work to do now. |
| Similar Threads | |||||
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| New Product | FTC HUNTER 680mm wingspan EPP Delta wing | Andy852 | Flying Wings | 23 | Oct 05, 2019 02:38 PM |
| New Product | FTC HUNTER 680mm Wingspan EPP Delta Wing | Andy852 | FPV Aircraft | 2 | Nov 13, 2017 05:32 PM |
| Build Log | Scratchbuilt fast delta wing plane | stef France | High Performance | 16 | Sep 18, 2014 11:01 PM |
| Help! | Scratchbuilt Delta wing help | ggradtech | Flying Wings | 0 | Sep 25, 2013 09:17 PM |
