Jul 01, 2018, 02:31 PM
EE Lightning F6
Thought it was time to dust off my old own design EE Lightning F6 and give it a flight as its been around 4 years since I last took it out.
Still goes just as I remember and wakes up all the locals so not to popular in the club. The landing was a bit hurried as I lost power and normally come in with power on but got away with just popping the magnetic hatch.
Stats are scale 1:13, wing span approx. 32 inch , weight 3.5 pound,
Power 6s 1500ma battery, motor is an EDF 1850Kv , 60 amp ESC , 6X6 CAM prop , the motor is mid mounted with an extension driveshaft.
It is as true to scale as I could get and can be a little tricky if speed is not kept up in the turns as it will drop the nose. I have added a 3 axis gyro this year and it does seem to tame the handling especially on launch as it used to torque roll quite bad.
20180622 173614 (2 min 20 sec)
Dec 21, 2018, 11:48 AM
Do you a plan for this Lightning which you can share ?
I'm looking for something about the size of yours.
Jan 02, 2019, 06:47 AM
Have sent you a PM with some information about my plans
Jan 07, 2019, 08:38 AM
Lover of scale R/C
Matt Halton's Avatar
Love it! Any build photos please?
Jan 07, 2019, 01:53 PM
Hi Matt have a few pictures from 2 builds using two different methods for the body, One wet moulded balsa over foam core the other strip plank.
The strip/foam nose plank looks very rough as this was a quick rebuild and I used a hot air gun to remove the original covering resulting in a number of burnt areas. I do have better pictures somewhere but cannot track them down at the moment.
Jan 11, 2019, 04:02 PM
Lover of scale R/C
Very nice build from wood. I love Lightnings.
Apr 10, 2019, 05:05 PM
Just thought I would post the vid of the last but one flight of my Lightning , should not have gone for that just one more flight a failing light was not good and a total loss resulted.
Anyway enjoy and the re-make is nearly complete
EE LIGHTNING BEXHILL 21082018 EDIT (1 min 50 sec)
Apr 16, 2019, 07:04 PM
Lover of scale R/C
Was I looking at the wrong video? It looked like a great landing to me.
Apr 17, 2019, 06:49 AM
Have corrected my text should have said last but one. Will be posting the full re-make soon but with twin EDF power.
Discussion EE Lightning F6 for 70mm Fans union1 Foamy EDFs 7 Jan 04, 2018 09:47 AM
Discussion EE Lightning F6 for 90mm union1 Foamy EDFs 65 Nov 12, 2017 06:27 AM
Discussion Scratchbuilt EE Lightning F.Mk 6 Matt Halton Scratchbuilt EDFs 7 Apr 19, 2017 08:22 AM
Build Log EE Lightning P1 .... solentlife Foamies (Scratchbuilt) 2 Feb 01, 2016 06:42 AM
Discussion EE Lightning F6 Tony Oliver Pusher Prop Jet Models 10 Feb 06, 2009 02:45 PM
