This thread is privately moderated by burkefj, who may elect to delete unwanted replies.
Jun 25, 2018, 10:27 AM
burkefj's Avatar
Skylab RC rocket glider
I always thought the Centuri Skylab rocket from the early 70's was neat but never had one. Being left alone for the weekend my mindsim got the better of me and decided to do an RC rocket glider themed version.
I sat down and did some mass balancing Sims to convince myself weight and dimensions would work and the location if the wing and lateral stability, then looked in my parts drawer. I had some 2" tubing and 2.6". I picked up a bt20 nose cone pack and two white motor tubes for the tail thruster.
I thought styrofam coffee cups might work for the transition and nose and lo and behold the base of the cups were 2". I also found some small paper cups and they nested in the base of the foam cups to extend the nose. I doubled the foam cups for support and used a Depron disk in between them for stiffness and glued a coupler through the base for a shoulder. I doubled the cups for strength.
I'm using an 11" chord Depron wing with two carbon spars. Glide tests are done and it is looking good. I picked up some gold monokote trim for the wing/solar panels because I think it will look better than silver. It's 43" long and 27.5" span and 7.25 oz dry, rtf should be right around 12.5 oz , no nose weight was required. the RX and battery are mounted in the transition section.
I picked up some aluminum tube for rail button standoffs because the nose diameter is larger than the rear by 1/2". I put some skids on the bottom to make it level with the nose when landing.
Got the stickershock decals to finish off the skylab RC RG and got in some test flights today, was a bit more windy than I wanted and I had to keep the nose down into the headwind to keep it from balooning but overall not bad.
Skylab satellite themed RC Rocket glider (5 min 11 sec)
Build Log BBCC8-Douglas F4D Skyray-Jetex FF to Rocket-glider RC builderdude Balsa Builders 191 Feb 15, 2019 06:57 PM
Discussion Pegasus RC Rocket Glider from Arkansas [Dynasoar Rocketry] crawf56 Rocketry 20 Mar 05, 2017 11:35 AM
