Jun 25, 2018, 06:07 AM
Quad Erat Demonstrandum
scousethief's Avatar
SST Racing 1/10 2.4G 4WD Drift High Speed 120km/h Off-Road Model RC Car
https://www.banggood.com/SST-Racing-110-2_4G-4WD-Drift-High-Speed-120kmh-Off-Road-Model-RC-Car-p-1314785.html
Average value for money , looks like the same chassis WLToys use just increased in size , great chassis but no real improvements , should be fun to blast around the park.
Description:
Basic information Model:SST
Scale:1/9
Material:ABS plastic Power System Motor: BL 3650/3300KV
Gear Ratio: 1:10.11
ESC Power: BL 45A (waterproof)
Servo Power: 9kgs(waterproof)
Charge:Included
Control way:Radio control
Transmitter Frequency: 2.4G
Channel: 2CH Battery Battery: Li-PO 7.4V 2700mAh
Transmitter battery:3x1.5AA(not included)
Other Using time:10-15min
Charging time:180min
Control distance:200m
Max speed:120km/h Dimension Axle distance:300mm
Tire dimension:93*38mm
Package size:32*19*17CM
Product size:43*22*22cm
SST rc car is the 1/9 ture car with all the film design material.
All the car use the super toughness engineer material,such as the alloy car chassis,three level metal differential 4WD system,adjustable shock absorber,dispatch motor.
The max speed can reach 120km/h which is satisfied with rc car amateur.
Feature:
1.Alloy super toughness engineer material ,thickness 2.5mm,6061T6 whole car chassis.
2.The front and rear shock absorded board use 4mm thickness alloy board which is more strength.
3.Large capacity adjustable Fillable oil shock absorber makes the car easier to turn left and right ans well as reduce the impact when the car attack the ground.
4.Adjustable and easily install motor,strength bushless 3650/3660 ESC.
5.Good quality 9KG servo provides it control more fun.
6.ESC seat can install big electric current bushless 45-80A esc(60x48x38cm)
7.Large capacity li-po battery provides more power to run.
Package included:
1x RC car
1x transmitter
1x charger
New Product JJRC Q36 2.4G 4WD 1:26 30+km/h Rock Crawler Off-Road RC Car -- FREE TEST BG Tobey Off-road Cars 142 Jun 22, 2019 10:42 PM
Discussion WLtoys 10402 1/10 2.4G 4WD High Speed 40km/h Buggy Off-Road RC Car scousethief Banggood.com 0 Jun 07, 2018 07:15 AM
New Product Feiyue FY-C10 1/12 2.4G Amphibious Vehicle High Speed Off-Road RC Car 35km/h abinge Off-road Cars 21 Mar 30, 2018 02:13 PM
New Product VKAR RACING BISON V2 2.4G 1:10 4WD Brushless Off-road with HOBBYWING 120A ESC RC Car GeekBuying Vendor Talk 0 Jan 16, 2018 04:05 AM
Discussion FEIYUE - 02 1 : 12 2.4G Full Scale SUV 4WD RC Off-road Racing Car S3MKi Off-road Cars 1 Feb 17, 2016 09:40 PM
