D-CAM - HD and Wide Vision
The D Cam features wifi, FPV, OSD, capabilities. Read on to learn more about this new camera from Detrum.
The D Cam Camera
From Dynam:
Small Size - The small size (42mm*75mm*22mm) and lightweight (with battery 62g, without battery 44g) make it very suitable for outdoor sports and FPV use.
Quad HD 2K - Provides 3 kinds of video resolution, the highest code rate can reach 24Mbps. Users can select Quad HD (2560*[email protected]) for high resolution, or select a high frame rate ([email protected], [email protected]) for smoother and more realistic video.
FPV Camera - The most popular application of D-CAM is carrying it on the aircraft for recording, connecting it to a video transmitter (such as Detrum DVT58). Then the video receiver and display device on the ground station can display the video sent from the D-CAM, to achieve FPV function.
Integrated OSD - D-CAM has integrated OSD function, then you can know the status of the camera in real time, such as battery level, video status, etc.
Wide Angle Lens - With a 2.5mm lens, the angle of field is FOV150°, which is wider than most of the cameras.
Very Simple to Use - You can take photos or recordings at any time without changing modes, it is very simple to use.
Low Power Consumption, Large Battery Capacity, Removable Battery - The D-CAM has a built-in 1050mAh battery, can carry out continuous recording for more than 90 minutes. Charging is very simple and you can start charging just by connecting the D-CAM USB port to the power supply without removing the battery. And the battery can be disassembled and replaced. Since then, there is no need to worry about running out of the battery.
Loop Recording - After this function is enabled, the recording process continues to record at the beginning, erasing the previously recorded material and replacing it with the content. The video segment length can be set.
USB Disk Mode - When switching to USB disk mode, you can access the SD card without removing the SD card, only by using a USB cable to connect the computer.
Support PWM Control, Take Photo/Recording Remotely - D-CAM outputs 2 PWM signals, you can use the cable included in the box to connect it to the receiver. Then you can take photo/recording remotely via the RC transmitter.
Support WiFi - With the self-developed APP, allows you to connect the camera via a mobile device for live preview, parameters settings (image quality, white balance, resolution, exposure, etc.), recording, photo shooting, sharing photo/recording to networks, etc.
The camera can be controlled from a distance to take photos and videos through the APP, and the distance can reach 30 meters without interference. Currently only Android APP is supported.
Specs
  • Sensor - 4 megapixels, 2umx2um
  • Angle of Field - FOV 150°
  • Encode Format - JPG, H.264
  • Video Resolution - 2560*[email protected], [email protected], [email protected]
  • Video Files - MP4
  • Audio - Stereo, [email protected]
  • TV Output - PAL/NTSC
  • SD Card - FAT32/exFat, max Micro SD Card supported is 64G (need class 10 or above)
  • Interface - Micro USB
  • WiFi - 2.4G
  • Battery Capacity - 1050mAh, continuous recording for more than 90 minutes
  • Dimension - 75mm*42mm*22mm(L*H*W)
  • Weight - 62g (with battery) /44g (without battery)
More Info
Head over to the Detrum site for more information and pricing.
Jun 20, 2018, 10:49 AM
We are not men, we are DEVO 7e
xanuser's Avatar
cool.
nice to see some new cams under 70 grams. (mobius maxi)
the true tale will be in their ability to handle fast lighting changes and if the bitrate is really enough.
Latest blog entry: MY notes/ Ascent 2"build notes
Jun 20, 2018, 11:56 AM
Will fly for food.
Jonathan Ott's Avatar
I can't access the site (firewalls at work, I guess) Don't leave us hanging, what's the price?
Jun 20, 2018, 12:05 PM
Admin Deluxe
Jim T. Graham's Avatar
Looks like $76.90. I updated that link as well.
Jun 21, 2018, 05:14 AM
Hamburger
hamburger's Avatar
it does support TV-analog out while recording HD to the SC-card?
what is the latency for TV-analog out ?
Jun 21, 2018, 07:37 AM
Will fly for food.
Thanks Billy!
Jun 22, 2018, 02:04 AM
Yes, it support TV-analog out while recording HD to the SD card.
The latency for TV-analog out is 120ms.
Jun 24, 2018, 01:15 AM
Registered User Friendly
ValHeli's Avatar
any vids on this?
Jun 24, 2018, 02:01 AM
xanuser's Avatar
Originally Posted by ValHeli
any vids on this?
and hopefully of the action variety. no walking tour videos please.
Jun 24, 2018, 08:47 AM
Is this a new revised version or still the same cam that came out last year? https://www.rcgroups.com/forums/show...n-for-sport%21
here is a sample vid
Detrum D-CAM 2K Fpv action camera (1 min 49 sec)
Discussion (D) Rep Jared Polis Bringing “Dreamer” To Trump Congress Speech kenpoprofessor Life, The Universe, and Politics 5 Mar 01, 2017 11:20 AM
Discussion How can I build a micro HD, wide angle, SD-card action cam? carve FPV Talk 2 Dec 09, 2015 09:36 AM
Discussion GoPro bringing high-def helmet cams to the masses, launching $180 HD Hero 960 flitelab Aerial Photography 1 Aug 04, 2010 03:02 PM
Cool GoPro HD Hero Wide - 6.3 oz HD video camera nemo_uk Aerial Photography 5 Sep 27, 2009 09:40 AM
New Product GoPro HD Hero Wide - High Def Helmet Cam Zirt57 Aerial Photography 7 Aug 01, 2009 12:27 PM
