Feb 16, 2019, 12:19 PM
olegss's Avatar
Fly
Feb 16, 2019, 02:12 PM
low tech high tech
vtdiy's Avatar
Wow!
Jul 30, 2019, 10:50 AM
olegss's Avatar
The active life of the cardboard plane continues.Actively fly on the old man.
картоныч посадка с тормозами (0 min 49 sec)
Work brakes.
картоныч тормоза (0 min 12 sec)
Jul 30, 2019, 11:10 AM
olegss's Avatar
Every year in Novosibirsk held an aviation show at the airport in Mochishche.
I took part in glider competitions held as part of the show.
He won the third place in a bitter struggle.
Jul 30, 2019, 11:19 AM
olegss's Avatar
A little view from the camera mounted on a cardboard glider. Cinema during the competition.
Шоу в Мочище старт картоныча (2 min 2 sec)
шоу в Мочище картоныч панорама со зрителя&#10 (2 min 2 sec)
шоу в Мочище картоныч птичка зрители (2 min 2 sec)
Jul 30, 2019, 11:27 AM
olegss's Avatar
Video flight of my cardboard glider hit the news of Novosibirsk.
Новосибирские авиамоделисты готовятся к (1 min 46 sec)
Jul 30, 2019, 04:51 PM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
COOL !!! Please , what is Russian word for “cardboard” ???
Latest blog entry: Lost plans
Jul 30, 2019, 09:43 PM
Sokol
JureZ's Avatar
something that phonetically sounds like "KARTON"
Jul 31, 2019, 11:13 AM
olegss's Avatar
Packing box. Here's an example box from IKEA store.
Jul 31, 2019, 11:15 AM
olegss's Avatar
Originally Posted by olegss
packing box. Here's an example box from ikea store.
123
Jul 31, 2019, 07:18 PM
Very nice! The craftsmanship is amazing! Any plans to try out in wing spoilers?
Aug 09, 2019, 10:12 AM
olegss's Avatar
A smoky cloud from the burning forests in the Krasnoyarsk region reached Novosibirsk.
Took a little video from the glider.
смог1 (2 min 2 sec)
смог2 (2 min 2 sec)
Aug 15, 2019, 12:53 PM
olegss's Avatar
Recently flew with a second set of wings on Cardboard.The first starts were not very good.
For such a scope, the aircraft has too weak wing mounts. All hlabano and hang out.
I had to tape it up.
Then it all went quite normal.
MVI 1783 (0 min 15 sec)
MVI 1784 (4 min 9 sec)
Aug 15, 2019, 12:58 PM
olegss's Avatar
You need to put the first version of the wing. I cut the tape with a machete.Got a lot.Moved the wings a little rest and a lot of flights to this embodiment.
Aug 15, 2019, 02:22 PM
Although made of cardboard these planes still rely to a degree on other materials for the highly stressed components like the wing spar.
Some cerial packets use a particularly dense yet thin cardboard so I wondered if such a material could be used in a fully load bearing stressed skin wing structure.
Clearly such cardboard would have adequate tensile strength so the question was just how much support would it need to handle the compression forces.
I already had a simple 40" span pusher that had a very successful wing made with 3 mm Depron skin and ribs with a balsa 'box' spar.
Description:
Fully aerobatic and flown regularly its wing has not been structurally repaired for 7 years.
The cardboard version is the same span but made up of 2 'panels' for each half. All the internal structure components are cut from 5 mm polystyrene laminate underlay.
Description:
The root has additional rib reinforcing to be able to resist the effects of the wing retaining rubber bands.
The outer panel contains the aileron servo.
Description:
Each panel is simply 'edge' glued together and reinforced with an external cardboard strip over the joint.
The completed wing on the same pusher plane.
Description:
At 5.25 oz (163 g) it is about 40% heavier than the Depron wing but it 30% more wing area and is made entirely from cardboard and foam!
I doubt it is as strong as the Depron/balsa wing so is flown 'gently' and limited to mild aerobatics but it gors well enough.
Cereal box wing (1 min 53 sec)
Cardboard plane tows high tech glider Dave H. Fly-A-Ways RC Club 5 Jul 09, 2017 08:17 PM
Discussion Any non- electric depron or cardboard flying wing plans out there? jarred.devito Flying Wings 4 Nov 30, 2015 12:53 PM
Discussion I need a larg plane to fly out 15 miles over ocean gtxkid Aerial Photography 64 Mar 19, 2015 06:12 AM
