Jun 23, 2018, 07:03 AM
olegss's Avatar
After celozivotni of ruder, to do telephony the Elevator. The mounting bracket is not made of cardboard, plywood, too...Made from aluminum the rear cover of the tablet. Very good aluminum, tough and moderately flexible.
At the same time fixing the Elevator.
Fitted a tail of Kraft paper to the PVA. Brought budeny.
Gathered all for control. Everything turned out exactly.
Finally gathered the entire stuffing.
Until such a heavy accumulator 2200. But I plan to use 1000 or 500.
Jun 23, 2018, 07:09 AM
olegss's Avatar
Calculated the center of gravity and made a removable front fuselage.
Everything stood up well, but dissatisfied. Made tight, not a sports variant was slightly looser and longer than the section of the spout.
I am not sure of the correctness of the calculations,and there is nowhere to retreat.
Completed airplane.
Empty glider.
The empty weight of the glider.
Jun 23, 2018, 07:15 AM
olegss's Avatar
Fixing the Elevator was questionable. Converted to a more solid mount.
Significantly extended the control lever on the Elevator.
Now everything works as I like.
The centre of gravity of all normal, properly considered.
MVI 0205 (0 min 9 sec)
Jun 23, 2018, 07:29 AM
olegss's Avatar
Very strong and rigid wing is obtained, including the torsion. It is clear, heavier, but not critically heavy.
I prefer to do what I like.
For protection from humidity painted the entire glider diluted glue. Bred two-thirds with alcohol.
To fly around much like.
I really wanted to, so flew around unfinished, not painted.
All holes are temporarily sealed with tape, built a lid from snow.
And here I am on a snow field, in far and terrible SIBERIA. Where full of wolves and bears-ha-ha-ha.
Jun 23, 2018, 07:34 AM
olegss's Avatar
First flight!!! Set the center of gravity a little forward.I was very worried, my hands were shaking. I haven't had such a big plane yet.
I went in several times to land, afraid to break.
SAT!!
test flight of a cardboard glider (4 min 2 sec)
And again!!!
test flight of a cardboard glider 2 (1 min 59 sec)
Jun 23, 2018, 07:36 AM
olegss's Avatar
Made 5 flights. Very happy.
THE CARDBOARD FLY!!!
Jun 23, 2018, 07:39 AM
olegss's Avatar
Now you need to do the little things.
And of course, PAINT!!!
Jun 23, 2018, 07:45 AM
olegss's Avatar
The next departure in the field on the painted and slightly upgraded equipment.
Decided to test the tail and wing. Removed from the car DVR, Velcro put on the plane. Quite a decent picture.
And so is the tail. I wanted to see how the tail boom works, control at the start,with a maximum load.
Wing with a bunch of snow, check for moisture.
video camera test (0 min 12 sec)
test the tail of the cardboard glider at the start (1 min 44 sec)
wing with snow (1 min 28 sec)
Jun 23, 2018, 07:49 AM
olegss's Avatar
Flew many times, enjoyed.
cardboard glider flight (3 min 17 sec)
flight 2 cardboard glider (4 min 37 sec)
3 cardboard glider flight (1 min 54 sec)
Jun 23, 2018, 07:52 AM
olegss's Avatar
https://www.youtube.com/watch?time_c...&v=zayqLMcLEhw
Jun 23, 2018, 08:04 AM
olegss's Avatar
Weight of different parts of the airframe.Wing 143Х19 see the Tail 30ch13.Elevator 60X12.After flying bent aluminum tube 8mm connecting the wings.Ordered carbon tubes.
Replaced the Central. It's much better!!!
Jun 23, 2018, 08:08 AM
olegss's Avatar
I fly again.
Fixed the DVR under the wing, it is a decent picture turned out.
https://www.youtube.com/watch?time_c...&v=6H5akleo9PI
live aboard a cardboard glider 2 (2 min 2 sec)
live aboard a cardboard glider 3 (2 min 2 sec)
Jun 23, 2018, 08:37 AM
olegss's Avatar
I flew a lot in the spring. Really strong wind.
Jun 23, 2018, 08:39 AM
olegss's Avatar
Summer is in full swing. A lot of sun and rain, grew on my airfield wonderful grass.
Jun 23, 2018, 08:48 AM
olegss's Avatar
Flew a lot and interesting, set up the glider.
And just flying, a lot. Finally great weather.
Shooting is almost not conducted, there was no time.
Grass on the field is wonderful, smooth soft.
Opened all for better cooling on the glider. Everything was closed in winter.
Great landing in the grass!!!
https://www.youtube.com/watch?time_c...&v=HCvbiRRwa_Y
Set another regulator for the motor, the brake has not yet adjusted.
flight of kartonaza rear alignment 3 (2 min 2 sec)
https://www.youtube.com/watch?time_c...&v=aW5hgxMXoTU
Experimented with settings and CT.
If you do not touch the control starts at fifty degrees, almost vertically.
Thirty seconds goes almost invisible, then in unison pours down.
You can see that the thermals throw it, but of course no good.
Although it can not be called a glider, just a big plane.
Cardboard plane tows high tech glider Dave H. Fly-A-Ways RC Club 5 Jul 09, 2017 08:17 PM
Discussion Any non- electric depron or cardboard flying wing plans out there? jarred.devito Flying Wings 4 Nov 30, 2015 12:53 PM
Discussion I need a larg plane to fly out 15 miles over ocean gtxkid Aerial Photography 64 Mar 19, 2015 06:12 AM
