Jun 18, 2018, 10:24 AM
olegss's Avatar
A large plane out of cardboard
Description:
Jun 18, 2018, 10:27 AM
olegss's Avatar
I'll tell you how to make a Big plane or glider from cardboard,
Jun 18, 2018, 12:41 PM
gpw
gpw
“There’s no place like Foam”
gpw's Avatar
OK, Good !!!
Latest blog entry: Lost plans
Jun 18, 2018, 01:32 PM
Electric Coolhunter
Thomas B's Avatar
Not an unknown practice here in the US. The now defunct RCM magazine published at least 4 or perhaps more model plans that used corrogated cardboard as the primary building material. I know other designs were published in other magazines as well. Worked OK for glow power, with suitable fuel proving. Even easier with electric power.
Foam is more popular due to the inherent characteristics of the material.
Latest blog entry: RC events for 2019!
Jun 19, 2018, 05:13 AM
gpw
gpw
gpw's Avatar
Let’s see what Oleg’s got !!! Maybe an innovation beyond what’s already published ….
Jun 23, 2018, 05:51 AM
olegss's Avatar
My first article about the possibility of making a cardboard is quite a decent plane, caused a mixed reaction of the brothers pilots.
I have described the construction of this aircraft on some forums here too.
http://www.parkflyer.ru/ru/blogs/view_entry/15644/
https://www.rcgroups.com/forums/show...ет
Bought in no clothing left IKEA, a coffee table. remained a good package. She made a little airplane.
Jun 23, 2018, 06:00 AM
olegss's Avatar
Now I know how to work with cardboard. I wanted to make a big plane like a glider. I didn't make them big.
The wing will be cardboard, large size. Just the size of other furniture box.
The corners are made of cardboard, it does not reinforce, for easy Assembly.
Vertical walls between the stringers made of cardboard.
Jun 23, 2018, 06:11 AM
olegss's Avatar
Power unit connecting the wing with the fuselage of plywood. Then there are the cardboard ribs.
Jun 23, 2018, 06:20 AM
olegss's Avatar
The kit insert wire management, connectors and servo.
Jun 23, 2018, 06:25 AM
olegss's Avatar
Continue wing.
Weight of one set.
Jun 23, 2018, 06:29 AM
olegss's Avatar
I mark the position of the set of glue miss the lower plane and glue.When glued to the bottom of the skin, cut through the position of the servos and Aileron, but not to the end. To avoid falling hatches. Then cut and cut through
Jun 23, 2018, 06:41 AM
If it flies - I want one!
Petem's Avatar
A very interesting approach, and fine craftsmanship - thank you!
PeteM
Jun 23, 2018, 06:43 AM
olegss's Avatar
Doubted the strength and replaced the connection to the aluminum pipe in 8mm.
Cut off the ailerons.All open edges are taped Kraft paper.Hung the ailerons on the hinges.
Deviations-up 30, down 90 degrees approximately.
Wings are ready.
Jun 23, 2018, 06:50 AM
olegss's Avatar
Not good durability "pure cardboard", had to be combined with plywood and sticks. The fourth option, the previous three in the trash..
The first design error, it was necessary to root the ribs and the side walls of the fuselage to drill at the same time, tortured to adjust the holes.
Assembled part of the fuselage to fasten the wings.
Set the wings, all right.
Closing the tail boom on three sides. Inside the partition, the holes for the Bowden.
Bowden from ear sticks. The joints are glued fix.
Jun 23, 2018, 06:56 AM
olegss's Avatar
Determined the position of the servos and dragged through the Bowden wire control 1mm. All is well and moves without complications. Taped the top cover, pressed.
Made all-round miner, inner set, coal tube in 4mm.
Cardboard plane tows high tech glider Dave H. Fly-A-Ways RC Club 5 Jul 09, 2017 08:17 PM
Discussion Any non- electric depron or cardboard flying wing plans out there? jarred.devito Flying Wings 4 Nov 30, 2015 12:53 PM
Discussion I need a larg plane to fly out 15 miles over ocean gtxkid Aerial Photography 64 Mar 19, 2015 06:12 AM
