Jun 16, 2018, 03:10 AM
New Product
RSSI Firmware mod for FlySky IA6B and X6B
Hello,
This one is for FlySky fans.
I just want announce a project I'v uploaded: https://github.com/Cleric-K/FlySkyRxFirmwareRssiMod.
It is a patched firmware for IAB6 and X6B receivers. It simply injects the Signal Strength value into IBUS channel 14.
I know that FlyPlus already allows something similar but it depends on the receiver being able to send back the telemetry back to the tx and then the tx send back the rssi data (which the rx knows anyway) as channel.
I hope it will be of use.
Happy Flying!
Jul 05, 2018, 11:22 AM
AWESOME! Thanks! I guess this would give a bit lower latency compared to rx -> tx -> rx -> fc route we do now with the hacked i6 firmware?
Jul 05, 2018, 11:24 AM
Also, any chance to have a look at a firmware for the flit10?
Jul 10, 2018, 03:40 AM
iNav settings
Can you add some description how to set it up in iNav?
Jul 11, 2018, 07:34 AM
Hi. If you can send me a dump of the firmware I can take a look. You should check if SWCLK and SWDIO pads are available. If not, it might be quite difficult to connect the stlink.
Jul 13, 2018, 09:08 AM
Cool, Iíll have a look next week (on vacay now).
Aug 02, 2018, 01:22 AM
It tested it yesterday and it works! THANK YOU
On my IA6C the Pads were mislabeled. I had to find out which are the corresponding pads by checking continuity from the STM32 SWDIO/CLK legs to the pads on the pcb.
In the end it worked and I now have RSSI. Thanks a 1000 times!
Aug 02, 2018, 04:21 AM
Great! I'm glad it all worked out fine.
Happy Flying!
Aug 16, 2018, 06:32 AM
Easy. Use Serial Rx, iBus. Select the port you use for iBus on the Ports tab.
Then go to the Rx page. Select channel 14 s the RSSI channel.
Exactly like betaflight.
Aug 21, 2018, 10:20 AM
Which were the correct pads? Can you maybe take a pic? My ia6c is covered in conformal coating, so it's very hard to check for continuity....
Aug 22, 2018, 04:55 AM
IA6C SWDIO/SWCLK pins
With the help of Trabireiter I managed to flash my ia6c receiver. The picture beneath shows the correct SWDIO and SWCLK pins. Number 1 has to be connected to SWDIO on the stlink dongle, number 2 to the SWCLK pin.
The labelling of the SWDIO and SWCLK pins on the receiver itself is wrong!
Aug 28, 2018, 02:30 AM
man u solved my big headache with ia6c on betaflight osd, was cominf from frsky to have 130mm quad and turnigy evolution radio to have a small and light backpack now i can have all i need
Aug 30, 2018, 12:53 AM
I flahedy i6ac but every time i enable rssi channel aux10 and reboot it shows disabled. Channel monitor seems ok but cant enable rssi
Aug 30, 2018, 02:04 AM
is everything else configured correctly? That same behavior can be experienced when the input configuration does not correspond to the actual physical setup.
Be sure that serial input is configured correctly for its uart, i-bus is set and then rssi on 10 should work.
thats what i did, used both firmwares on repo, your and clerick. each time i enable rssi aux10 i got no luck reboot and get disabled. all other stich channels and aux respond, even aux 10 goes 1400, 1700 , up and down, when i switch off tx get 1500 on aux 10
rssi value is 31 always meanwhile on tx i got signal correct
betaflight 3.4.0, 3.4.1, omnibus f3, uart serial rx enabled, receiver i6ac , tx turnigy evolution,
will give a try again at home after work, i did not changed rx id as suggested by polvhp because have to check how to do in hex editor.
Discussion FlySky / Turnigy iA6 (and iA6B) voltage telemetry mod triibutu Radios 281 Aug 07, 2021 01:30 PM
Discussion FlySky x6b RSSI in OSD with betaflight omnibus F3 tekknyne3 Radios 4 Jun 26, 2018 12:09 PM
Discussion Using telemetry with Flysky i6 : iA6B or iA10 ? Denis Poulain Radios 12 Jul 21, 2017 04:19 AM
Discussion FlySky iA6b receiver with S-Bus and RSSI meter vladG Radios 5 Jul 06, 2017 06:45 AM
