Jun 23, 2018, 10:43 AM
j_whitney's Avatar
The safe bet would be to send both back. A lot cheaper than potentially losing an airplane and maybe causing an injury,
Jun 23, 2018, 01:11 PM
I would agree ...... and agree with Jim too regarding never seen an LED go bad.....
I guess there is a first for everything but my gut feeling is that there's something going on beyond that......
One thing that was not suggested to the OP is to try the module in another radio to see if the led comes on.
Jun 23, 2018, 07:05 PM
comes on in the DSM2 module in this radio.
Jun 23, 2018, 08:17 PM
Try your “defective “ module in a DIFFERENT radio to see what happens....
Jun 24, 2018, 11:28 AM
Wait - on you referring to the transmit LED on the Futaba radio itself? Are you looking at the LED on the XtremeLink transmitter module?
Jun 24, 2018, 11:54 AM
XPS module, LED is dead. I have not tried it in another transmitter though.
Jun 24, 2018, 02:29 PM
Please humor me and try it in another transmitter.......
Jun 25, 2018, 06:03 PM
Plugged it into a friends 8U this morning, no LED. Still flies everything fine.
Jun 25, 2018, 06:15 PM
Thanks for doing that “test”
I’ll be watching for Jim’s report once you send it back for service.....
You are sending it back , right ???
Jun 26, 2018, 08:31 PM
Its in the mail!
Jun 27, 2018, 01:33 AM
OK, thanks for the heads up.
Jun 30, 2018, 02:37 PM
Module received. LED was fine. However, I think you must have had a fit of rage and threw your transmitter, because the small 2 resistor pack for the LED was knocked about 60 degrees off center. The solder joints (4 of them, 2 at each end of the part) were actually broken. I am guessing this would have had to have been a solder issue during production or something. Easy fix, just straightened it out and resoldered both sides. It will go back to you on Monday.
Jun 30, 2018, 03:05 PM
Whew !!! Mystery solved !
That’s great service , Jim .....
Jun 30, 2018, 08:17 PM
@Vapor52, did you ever drop the transmitter or the module? It would take some considerable force to do this.
Jul 01, 2018, 11:02 AM
Never. I thought you were joking.
Discussion DIY Spektrum module won't bind (re: Prikkel mod, X7, and Blade Nano QX) sofakng DIY Electronics 0 May 14, 2018 02:25 PM
Help! Ezuhf won't bind, DX6 won't communicate Cbradley1967 FPV Equipment 1 Feb 01, 2018 06:35 AM
Help! Orangetx Module won't bind in walkera mode. SocJon23 Radios 4 May 08, 2017 05:39 PM
Discussion DM9 Spektrum Module in XP8103 Won't Bind? Chachi639 Radios 27 Nov 01, 2015 05:59 PM
Question Nano III won't bind to JR 9303 Module? G-Forse Xtreme Power Systems 3 Aug 09, 2015 02:26 PM
