Jun 15, 2018, 03:24 AM
dartita's Avatar
New Product
TOPSKY Prime1 Goggle Dual Modules FPV Glasses
TOPSKY Prime1 4:3 40CH Goggle Dual Modules Antennas FPV Glasses
New $80 goggles from TopSky
Official Website: http://www.topsky-en.com/products/prime-1
Gearbest: LINK
Main Features:
● One FPV glasses designed for beginner players
● Simple operation: most of the operations can be completed with a key
● Adjustable diopter, suitable for nearsighted players: 0 - 800 myopia can be adjusted manually
● Built-in dual modules and dual antennas greatly increase the receiving distance and stability
● Auto sound and icon alarm when in low voltage or low signal
● Up to 86 degrees FOV
Specifications:
Frequency: 5.8G
Channels: 40
Search function: auto
General
Brand: TOPSKY
FPV Equipments: FPV Goggles
Functions: Video
FPV Goggles
Resolution: 320 x 240
TV System: NTSC / PAL Switchable
Screen size: 4:3 2.4 inch
Battery Information: 7.4V 1300mAh LiPo
Operating Voltage Range: 7.4 - 9V
Working Time: 3 - 4h
Charge time: 2h
Sensitivity: -95dBM
Antenna: 2 5dBi antennas, SMA connector
Dimension and Weight
Product weight: 0.1900 kg
Package weight: 1.2500 kg
Product size (L x W x H): 15.50 x 5.00 x 6.90 cm / 6.1 x 1.97 x 2.72 inches
Package size (L x W x H): 24.00 x 13.00 x 15.00 cm / 9.45 x 5.12 x 5.91 inches
Package Contents
Package Contents: 1 x FPV Goggle, 1 x Glasses Cloth, 1 x Antenna, 1 x Tie, 1 x English Manual, 1 x AV Cable, 1 x Mic 5 Pin Cable
Jun 15, 2018, 04:02 AM
One more useless model on the market. 320x240 in 2018 year... why not 160x120 or 80x60?
Jun 15, 2018, 04:54 AM
SeByDocKy's Avatar
1x1 ....
Jun 15, 2018, 02:35 PM
How do they states an 86 degree FOV with a 320x240 screen? That picture would be so large but blurry that you couldn't possibly fly off of them.
Jun 17, 2018, 05:32 AM
Topsky Prime1 is here! (0 min 58 sec)
Jun 22, 2018, 12:17 AM
You beat me on that question... I came up with the exact same conclusion... not only there is less pixels but with 86 FOV you may be able to see only half of them at once.
Jun 22, 2018, 10:49 PM
I just copy paste my answer from another thread here.
To clarify that open questions, I may speak for TOPSKY.
What is Prime1?
The first entry into FPV can be expensive, growing out of cheap gear is always around the corner.
We tried to create a good bang for the buck, threw in some safety features and wanna offer "Affordable FPV for everyone!"
The resolution topic:
Prime1 has a VR resolution of 640x480.
A Box Goggle (one screen) 640x480 equals to what the Prime1 (two screen) will produce.
The two big screens measure 2.4 inch which gives a better result than stretching out smaller screens. One great advantage of 2x bigger screens instead of 1x huge screen is to reduce the eye distance and therfore unit size for quite a lot.
Getting back to customer needs, the design is compact enough that we were able to add a built-in diopter.
Another feature that has been asked for was a RGB adjustment feature, which can greatly correct a cameras color misinterpretation.
The above mentioned EV100 comparison:
A 720x540, 0.xx inch micro-screen gets stretched to a 28 FOV; Our approach was different.
In our opinion, a high pixel density on a small screen can not display a colorful and bright picture, neither the higher resolution can deliver more details within a small FOV. We wanted more view! We listened to customers, and tried to do a better approach.
The antenna topic:
Prime1 comes with 2x 5.8g modules in diversity mode, each module has 2x SMA outputs which makes in total 4 antennas.
Speaking of reception, we can report that we could manage to have more than 2dBm additional sensitivity (RF speech -2dBm more) to built-in receivers in current competitor products in the same price category.
Each 6dBm step doubles range.
Especially in terms of antenna orientation and placement, as well as possibility to add directional antennas to get a better signal coverage, we speak of trying to get 360 degrees, the reason for that design. Each module can be deactivated to save power.
Jun 22, 2018, 11:01 PM
What is Prime1?
The antenna topic:
Yeah, That's not actually how resolution works with dual screen setups, but I guess we'll wait and see. Not gonna shoot it down before I see a review on them.
Jun 26, 2018, 10:28 AM
This "VR Resolution of 640x480" is nonsense. It seems like a trick to try to get "640x480" into the specs so people will not notice that the actual screen resolution is 320x240.
Nobody else specs their goggles this way. By this metric, HD2 resolution is 1600x1200. Okay then... but it's not. And it's B.S.
Nobody should make a 320x240 FPV goggle in 2018, at any price.
Nobody should buy a 320x240 FpV goggle in 2018, at any price.
For all my complaint about the EV100 with its tiny FOV, at least they had the sense to spec a high resolution screen.
This goggle is dead in the water, in my opinion. Which is a shame, because the 4x diversity receiver with antennas pointing out the side is actually very clever. The adjustable diopter is very clever (-8.00 diopter, which is even better, because most only go to -6.00 and I am -6.75 so this would be very good for me).
Dear Topsky: I said it about the F7X -- you are so close to making a very good goggle, and then you make a few mistakes that kill it. You're doing it again. Go back to the drawing board and re-make this goggle with minimum 640x480 screen and it might be okay. At 320x240, it is not even worth looking at.
Jun 26, 2018, 10:43 AM
UAV Flight Operations Manager
I completely agree with Joshua.
I purchased my first video goggles from RangeVideo in 2009 and they were 640 X 480...
Jun 26, 2018, 11:17 AM
Glenwood's Avatar
Agree with the above. There are compromises that are reasonable to save money on budget goggles (e.g. being big/bulky like box goggles) but screens that are even lower res than the low-res analogue signals we're already suffering is ridiculous.
Jun 26, 2018, 04:32 PM
Jun 26, 2018, 04:57 PM
Double post - sorry
Jun 30, 2018, 11:49 AM
aka KF7DS
Glad you did double post or I would not have seen this....incredibly funny 😄
Jul 01, 2018, 06:56 PM
Lol
This needed to be double posted LOL
New Product Updated - Comments from Topsky on newer version of F7X FPV Goggles BobFromMars FPV Equipment 1850 Sep 01, 2019 09:00 AM
New Product TOPSKY F7X 2D 3D 5.8G 40CH 16:9 FPV Goggles Video Glasses With Battery Support HDMI Drra FPV Talk 86 Sep 28, 2017 01:12 PM
Discussion TOPSKY F7X 2D 3D 5.8G 40CH 16:9 FPV Goggles Video Glasses With Battery Support HDMI D Reteeph FPV Equipment 2 Sep 22, 2017 03:16 PM
Cool WSX-F01 5.8G 40CH Raceband FPV Goggles Video Glasses with Dual Antenna cooperationRC Multirotor Drone Talk 0 Feb 13, 2017 02:13 AM
