Tonka Summit Tail lights. - RC Groups
This thread is privately moderated by DeadlyPope, who may elect to delete unwanted replies.
Jun 13, 2018, 03:39 PM
DeadlyPope's Avatar
The Tonka Summit Arizona Needs more!!!
So..... I can't stand the area where the tail lights are supposed to be on the Tonka body, Paint = FAIL , Reflector Tape = FAIL.
Lets make real ones...
cheapo reflectors with sticky back tape from ACE Hardware,
a Dremel, a caliper(for measuring shape and dimensions) , and a Benzomatic gas soldering iron without the tip to heat up the reflector to bend into shape.
After Fitting , holes will need to be drilled for LED's behind the tail light lens.
NOTE: I have noticed that the putting light through the back of the reflector is not optimum.
So i will grind down the triangular shaped reflections to let more light through instead of bouncing on to much of an angle.
Jun 13, 2018, 06:02 PM
DeadlyPope's Avatar
almost molded correctly... then add some trim
