This thread is privately moderated by racerdee, who may elect to delete unwanted replies.
Jun 13, 2018, 10:22 AM
racerdee
Build Log
B-17 DTFB Design Test build wing
Sorry for the picture quality, this is what I have so far. the cowling is 10 inches by 2 inches and then I rounded it. the wing is 22 inches (overall wingspan when the plane is finished = 44in). Cord, where the wing meets the fuselage, is 8 inches. the trailing edge is kind of choppy that's because the ruler kept sliding and it didn't matter how much I pushed on the ruler. This was just a test build to see if my idea would work, my thought process was that if I put tabs on the top and bottom of the wing, could I cut the power pack in half and it still work? Well, I got the bottom pieces attached and realized that the airfoil of my wing was the same thickness as the powerpack half, so, I had to go back into Inkscape and double the walls back up and it ended up working. If I get this plane to fly, ill consider posting plans if anyone is interested.
What I plan on doing is running an aluminum spar down half of one wing and half of the other and putting the dihedral in that way, I may consider adding a carbon fiber rod into each wing for strength.
Any comments or advice would be great, questions, ill do my best to answer them, like I said in my first entry this is all new to me, still learning any input helps.
thanks,
Ruttledge James
Discussion Building Flying Wing for AIAA Design Build and Fly Muhammad Fahad Flying Wings 4 Dec 29, 2017 08:22 AM
Build Log THERMALPLEX DLG - Design, Build, Test, Optimize, Produce, a Flying Wing DLG... RobertTHaas Hand Launch 254 Dec 31, 2015 07:42 PM
Idea Spar and Chord DTFB Flying Wing Build Holski77 Flying Wings 2 Sep 27, 2015 11:08 AM
