Build Log
Furio
The Breta Furio was the go-to glider for F3B back in 2007.
I got one second hand back then and flew the flaps off it over the next few years. Slope, thermal, F3B/F and even DS'ing with a home-made wing joiner that was still curing after 24 hrs. Fast forward to 2018 and another has landed on the work bench. Untouched, never been built. Dry weight 1921g = 67.8 oz |
Fun!
Furio V Milang F3J 2009
Milang F3J 2009
Mike Rae won the fly-offs with his Kermit-Green Furio-V. Joe dominated the prelims with a new glider glider called a "Supra". Fly-Offs 1 Mike Rae 2 Joe Wurts 3 Carl Strautins 4 Mike O'Reilly 5 Alan Mayhew 6 Tim Kullack 7 Jamie Nancarrow Prelims 1 Joe Wurts 2 Carl Strautins 3 Mike Rae 4 Mike O'Reilly 5 Alan Mayhew 6 Jamie Nancarrow 7 Tim Kullack 8 Theo Arvanitakis 9 Mike Richardson 10 Nick Chabrel |
Aileron servos
Aileron servos:
So sweet! I’d love to give it a run. I loved all my NYX and Futio’s.
Stable and fast. P |
Radio Tray
Copper etched off PCB in a bath with the magic powder.
First effort was laminated and had the ruder servo offset to clear a ballast bar but I don't reckon I'll bother with fuz ballast at this stage. The tray was also 31 grams and too heavy so Take 2 which will be just a single layer PCB with rudder mounted more centrally. Key here is to mount the tray low down so the elevator pushrod clears the joiner. |
It is refreshing to see an "old school" style servo install with a modern twist. Lots of room, simple and straight forward; nothing tricky or complicated. And it will work!
I have a similar build on the bench. It is only a 60"er, but a set up that looks the same. Thanks for sharing, Adam |
Old School Z-Bend
Tray fixed in with JB Weld but not before slotting the sides of the tray with a Dremel.
Just a very shallow recesses enough for the glue to flow into. Z-bend pliers made light work of the rudder pushrod, a drop of MediumZap to eliminate slop. |
Canopy & Servos
Still waiting on servos (94761) for flaps.
Ordered 15thJune. Where does everyone get their 94761 fix? While waiting for the servos it's a good chance to make a 'glass canopy. The carbon one is lovely but carbon's bad for radio reception. Three layers of 2oz satin-weave should do it. |
Reason: Added fibre
...but the rest of the fuz looks like carbon/kevlar weave??
Canopy Upgrade
New canopy has saved 9g but more importantly is 2.4 transparent.
Flap servos still on a slow boat from Hong Kong. |
Nice!
It’s gonna be a fun one. |
Slow boat from Hong Kong
Assembly done
Servos installed
Wiring done MPX connectors are JB welded into the wing roots MPX sockets fixed in fuz with West Systems 24hr 4-cell Eneloop 2000mAh AUW 2271g = 80oz Maiden imminent.
Thread Tools | |
Similar Threads | |||||
Discussion | Nyx Furio 2-piece V-tail... | SpeedMaster | Multi Task F3X | 47 | Apr 08, 2008 04:03 PM |
Alert | Cheap Furio knock-off | DrFragnasty | Sailplane Talk | 6 | Mar 31, 2008 02:14 AM |
Mini-HowTo | Furio Renovation Rescue | DrFragnasty | Sailplane Talk | 0 | Jan 24, 2008 07:39 AM |
Video | WP F3F- Kyle & Furio 5-28-07 | F3X | Sailplane Talk | 3 | May 30, 2007 01:39 PM |
