This thread is privately moderated by pjwt56, who may elect to delete unwanted replies.
Jun 12, 2018, 02:07 PM
Trader Rating: 28
$450.00 USD
Will not ship
Sold
Top Flite 1/5 Giant P-51D Mustang GP ARF 2.1-2.8, 84.5" Wingspan "New in Box"
TOP FLITE 1/5 GIANT P-51D MUSTANG GP ARF 2.1-2.8, 84.5" Wingspan! "New in the box". This Mustang is brand new and never removed from the box. Just don't think I'll ever get to building this. Just no more room. First $450 takes this steal of a deal on a Great Top Flite Warbird. Local pick up only. Very big box.
FEATURES
Construction: Fully sheeted balsa and plywood with pre-painted
fiberglass fillets
Wing: One-piece, built up wood frame which is then sheeted with wood
Covering: Factory applied Top Flite MonoKote in color scheme to
recreate WWII's "Big Beautiful Doll" flown by Col John D Landers
Radio Compartment: Easily accessible, plywood reinforced
Cowling: Fiberglass, Pre-Painted
Canopy: Clear, single
Landing Gear: Fixed heavy duty wire ("), but is also set up to use
optional Robart retracts with functional landing gear doors
Dual Wing Servos: Two servos per wing half (1 Flap, 1 Aileron)
Spinner: 5" (127mm) Aluminum
Cockpit Kit: Pre-Painted ABS plastic with decals
Building Time: Ready to fly in only 25-30 hours.
Warranty: Top Flite Models guarantees this kit free of defects
in material and workmanship at the date of purchase.
Warranty does not cover any component parts damaged by use or
modification
INCLUDES
Pre-built and covered wings, fuselage and tail assemblies, pushrods,
pre-bent " (6mm) fixed main landing gear, 5" (127mm) main wheels
2" (51mm) tailwheel, adjustable engine mount, 32oz (960cc) fuel
tank with glow stopper (for gas use DUBQ0675,not included),
5" (127mm) spinner, wood servo trays and wing joiner,
extensive hardware package and photo-illustrated instructions
also includes full set of colored decals
REQUIREMENTS
Engine: 2.1 -2.8 cu in (34.5 - 46cc) 2-stroke
OR 2.5 -4.3 cu in (41-70 cc) spark ignition gasoline engine
Muffler: Pitts style
Radio: 5 - 7 channel
Servos: 10-11 Standard (2-Aileron, 2-Elevator, 1-Throttle, 1-Rudder,
2-Flaps, 1-Tail Steering, 1-Air Control Valve)
(a high torque servo is suggested for the rudder, but not required)
Servo Extensions: (2) 24" Extension, (1) Dual Servo Extension
(4) 6" Extensions
Y-Harness: (1) Y-harness for flaps
Misc. Items: Glow plug, 1/4" foam rubber padding, medium fuel tubing,
fuel filter, propeller, building and field equipment.
SPECIFICATIONS
Wingspan: 84.5" (2146mm)
Wing Area: 1245 sq in (80.3 sq dm)
Weight: 19 - 24 lbs (8.61 - 10.88kg)
Wing Loading: 32 - 35 oz/sq ft (98 - 107 g/sq dm)
Length: 73.5" (1865mm)
Airfoil: Fully-symmetrical, low-wing
Center of Gravity: 4-9/16" (116mm) Back from the wing's leading edge
Control Throws: High Rate Low Rate
Elevator: Up & Down 9/16" (14mm) 3/8" (10mm)
Rudder: Right to Left 1" (38mm) 1" (25mm)
Ailerons: Up & Down " (19mm)up " (13mm)up
5/8" (16mm)down 3/8" (10mm)down
Flaps: 1-3/16" (30mm) 2-1/8" (55mm)
COMMENTS
Pilot shown inside the plane is not included.
This kit is covered in the following Top Flite MonoKote colors:
Aluminum (TOPQ0205) base color
Flat Olive Drab (TOPQ0510) anti-glare
Black (TOPQ0208) rudder, nose checkers
White (TOPQ0204) nose checkers
True Red (TOPQ0227) pin striping
If retractable landing gear is desired, the following items will be
needed:
ROBQ1635-#622-5 Landing Gear ROBQ2305-#157VRX Air Control Kit
ROBQ2225-#160LWC Tail Gear Assembly ROBQ2369-#169 Tubing
2x DUBQ0847-#500TL Wheel
DUBQ0860-1" (45mm) Tailwheel
Electric retracts are also available from Robart, ROBQ163
Jun 25, 2018, 12:01 AM
Trader Rating: 2
JLayes's Avatar
I pm you
Off Site Top Flite Giant P-51D Mustang ARF 2.1-2.8,84.5" $199.99 Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 8 Sep 17, 2016 09:38 AM
Off Site Top Flite Giant P-51D Mustang ARF 2.1-2.8,84.5" Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 3 Sep 13, 2016 01:34 PM
Sold Price reduction!!! Top Flite Giant P-51D Mustang ARF 2.1-2.8,84.5" $375.00 Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 3 Sep 12, 2016 02:54 PM
Sold Price reduction!!! Top Flite Giant P-51D Mustang ARF 2.1-2.8,84.5" Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 8 Aug 22, 2016 09:45 PM
Sold Top Flite Giant P-51D Mustang ARF 2.1-2.8,84.5" Mike Fortune Aircraft - Fuel - Airplanes (FS/W) 0 Aug 14, 2016 05:09 PM
