How to make "hollow" canopies and fuselages??? - RC Groups
Jun 12, 2018, 11:41 AM
trying2flyit's Avatar
I would like to know how to make hollow fuses and canopies out of dollar tree foam? I really don't like the look of square fuselages on scale planes like a P-38 Lightening. If any one has ideas on making curved fuses,etc. please let me know. Thank you so much!!
Jun 12, 2018, 09:02 PM
treefinder
springer's Avatar
Took a while, as it isn't an active thread, but this guy has done some great work forming foam into complex shapes. https://www.rcgroups.com/forums/show...th-foam-sheets
You can also click on my username and go to my blog. Look for the list of one skeeters so far. It has links to the build threads. Some of my planes have rounded fuselage and other shaped parts. Not as good as osern, but another take on shaping foam.
Jun 13, 2018, 10:21 PM
1/2 ounce fiberglass clothe epoxy
I shape my foam mold and then I coat it with diluted epoxy. After sanding it smooth , I reapply another coating.I then Epoxy cover the mold with 2 layers of 1/2 ounce fiber clothe . A final coat of 2 ounce cloth is epoxied on .I then use acetone to dissolve the foam mold and then you have to grind out the caramelized foam.
Proof Of Concept - Styrofoam, Epoxy, Fiberglass, Acetone (3 min 20 sec)
Jun 14, 2018, 02:50 AM
Build straight - Fly twisty
Whiskers's Avatar
That's pretty cute, but I think vacuum forming would be easier, cheaper and lighter (depending on material used)
The plug would need to be harder than foam, and therefore slightly more difficult to make, but it would not be destroyed in use.
Actually the above method could be a good way to make the vacuum-forming plug.
Jun 14, 2018, 04:39 PM
thanx!!!!!!!!!!!!
Jun 16, 2018, 02:41 PM
This thread may be of interest, along with many more from Juergen:
https://www.rcgroups.com/forums/show...e-easyiest-way
Mark
Question How do they make hollow square wing joiners? Dbox Composites Fabrication 11 Feb 14, 2013 04:28 PM
Discussion Question about making a hollow-log fuselage; a change of plans RknRusty The Builders Workshop 14 Aug 23, 2011 08:35 AM
Question How do you make sealed hollow molded Ailerons or Flaps? tommyt Composites Fabrication 5 Oct 25, 2007 12:16 PM
Discussion How to build a hollow EPP fuselage stanordave Foamies (Kits) 5 May 24, 2006 11:02 AM
How do they make hollow molded wings? TheTick Slope 4 Jul 25, 2003 12:56 AM
