Jun 11, 2018, 02:52 PM
Adapting 12mm mounting to 16mm
I'm trying to builda light spec 5 incher. I purchased an Amax Inno Nano 5 frame and am trying to mount the Hyperlite 2204s to these arms. The bolt pattern on the motors are 16mm x 16mm and the arms are 12mm x 12 mm. Any ideas how I can make this work? The arms are cut in such a way that I can turn the mounts 45 degrees and possibly strattle the arm with some sort of plate below it. Any thoughts?
https://www.amaxshop.com/image/cache...50-700x850.jpg
Jun 11, 2018, 09:33 PM
Bump
Jun 13, 2018, 09:36 PM
What about using something like brotherhobby R4 1806? Legend has it, there is a 2500kv version, but I can only ever find the 2850. It is M3 on 12mm pattern, you just may need to drill out the M2 holes to M3 if the frame has M2 motor holes.
https://www.getfpv.com/brotherhobby-...ess-motor.html
Jun 14, 2018, 03:21 PM
I don't know why I had it stuck in my head that 1806 wouldn't be enough power for this build but really, this motor looks to be the same thrust numbers and weight. Unfortunately I already ordered the other motors and received them. I guess it's not the end of the world.
Thanks for the link on the motors. I'll likely order these.
Jun 14, 2018, 07:12 PM
Those 2204 are nice motors too, you should have no trouble selling them on the classifieds here.
Discussion 12mm to 17mm adapters? Any generic alternatives to the cheap ebay adapters? DougT Off-road Cars 1 Mar 09, 2016 08:48 PM
Discussion X8 motor mounts for 16mm CF tubes slimething Multirotor Drone Talk 3 Feb 23, 2015 10:20 PM
Help! 16mm carbon tube landing gear mount avermat Scratchbuilt Multirotor Drones 20 Jun 24, 2014 08:46 AM
Discussion constuction for a 12mm and 16mm stator ueliisa Electric Motor Design and Construction 17 Apr 06, 2007 11:22 AM
Question APC props on 12mm adapter Andy W Power Systems 11 Jan 14, 2007 10:47 PM
