This thread is privately moderated by Gary Chen, who may elect to delete unwanted replies.
Jun 11, 2018, 01:36 AM
30X EO/IR Drone Gimbal,50mm Lens,With Tracking And Geotagging
30X EO/IR Gimbal With 50mm Lens,With Tracking And Geotagging (4 min 33 sec)
30X EO/IR Drone Zoom Camera With 50mm Lens (3 min 57 sec)
Eagle Eye-30IE-50 is a 3-axis high stabilized EO/IR dual sensor gimbal for drone inspection,surveillance,search and rescue applications.
The daylight sensor is from SONY FCB-EV7520,the 30X zoom camera provides 1080P 60FPS full HD video streaming and up to 360X zoom capability,which enable you to see every detail you need in the air even you are far away from the object.While the thermal camera is with 640*480 resolution,25HZ,allows you to detect targets in the night or low visibile conditions,and provides you with priceless information.Furthere more,the thermal camera comes with a 50mm lens,which will enable you to get very clear thermal image even you are 500 meters away from the target.So this EO/IR gimbal is very suitable for long range surveillance and security missions.
High-performance 3-axis gimbal is developed based on FOC(field-oriented control) technology,which will give you crystal clear video footage.
Eagle Eye-30IE-50 is using the most advanced thermal tracking technology,with which you will never lose the object,the tracking function works on daylight sensor too.How it works:zoom in and put the object you want to track in the screen,move the cursor to the object and lock it via controller,and then the camera will track it automatically.
Another big feature for Eagle Eye-30IE-50 is that the gimbal will geotag the video streaming and photos,also gimbal Yaw/Pitch angle,height,time information will be displayed on camera OSD,this is really important when you are conducting missions like rescue and search.
Eagle Eye-30IE-50 comes with an amazing advantage that the gimbal can not only be controlled via PWM signal,but also serial command.Also gimbal status(like Yaw/Pitch/Roll angle,zoom position etc) can be obtained by sending serial command to the gimbal via its serial port,which is really useful for precise gimbal control and system integration.
Eagle Eye-30IE-50 provides an outstanding wiring hub design for RC receiver and video output port,which makes wiring pretty easily.Also the gimbal offers 2 smart speed modes:FAST speed and LOW speed.Fast speed mode is used for small zooming range,which makes the gimbal control sensitive and quick.LOW speed mode is used for large zoom range,will enable you to target the object more accurately
Features
1) Weight:1200grams(cameras included)
2) 1/2.8 inch 2.13MP CMOS sensor
3) 30X optical zoom,1080P/60 HDMI output for video downlink
4) 1080P/30 H.264 video recorded for on-board TF card
5) Thermal camera:640*480,25HZ,50mm lens,1X/3X digital zoom
6) Auto object tracking function
7) Geotagging,gimbal Yaw/Pitch angle info,height,time will be displayed
8) PWM control and serial command control
9) Convenient wiring hub for RC receiver and video output
10) 3-aixs high stabilized gimbal system
11) Adjustable control speed: SLOW speed for large zoom range,accurate.FAST speed
for small zoom range,sensitive and quick.
12) One key back to home position
Product link
http://www.yangdaonline.com/eagle-ey...nd-geotagging/
New Product EAGLE EYE-30IE 30X EO/IR DUAL SENSOR 50mm LENS FOR THERMAL CAMERA charlesfang Multirotor Drone Talk 0 Jun 08, 2018 02:17 AM
Discussion 30X EO/IR drone zoom camera with object tracking and geotagging Gary Chen Multirotor Drone Talk 1 Oct 22, 2017 09:43 PM
