UF-1401 ( 4 emitters / 4*18650 ) - Another flashlight review - RC Groups
This thread is privately moderated by old4570, who may elect to delete unwanted replies.
Jun 06, 2018, 07:04 PM
Mini-Review
Brand: UniqueFire
Model: UF-1401
Emitters: 4 x Cree XM-L2
Luminous Flux: 3500Lm
Mode: 5 (High > Mid > Low > Strobe > SOS)
Battery: 4 x 18650 battery
For review courtesy FastTech.com
Product page @ FastTech.com
Before I started taking light measurements and stuff , I wanted to take the UF1401 for a walk . The walk as it turns out is around 4 kilometers which is a fair distance . Putting the UF-1401 on the scales with 4*18650 inside I got some 635 grams . Ouch ! and the bummer is the UF1401 has no attachment points , none ( The UF-1401 begs a sling ) . So either put it in a bag or carry it around in your hand ( Which I did - carry it about in my hand ) . Walking about and using the UF-1401 I quickly found most of the lights short comings , the on off / mode button is just a little too flush to give any sort of feedback when wearing gloves . 3 Output modes are not enough , LOW is too low for the suburbs , MEDIUM is too high and High is embarrassingly high .
Which brings me to the order of the modes , the light always starts in HIGH . With a light that produces as much power as the UF-1401 the light should start in LOW . Also the way the light starts ( Hold the switch down for about 3 seconds ) is cumbersome and slow . I understand that this has probably been done to stop accidental activation , but all one needs to do in that regard is untwist the body to effectively lock out contact ( flow of current ) .
The UF-1401 does one thing really well . It pumps on high , it does not have huge throw but it does have huge flood and out to maybe 150 meters , there is no where to hide . Seriously I think you could play a football match with two of these lighting up the field . The UF-1401 really begs 2 more light levels . There needs to be something between LOW and MEDIUM around 80 to 100 Lumens and another light level between MEDIUM and HIGH because the gap between medium and high is just massive .
PERFORMANCE:
This is most likely what most readers are interested in so I wont keep you waiting .
HIGH - On start the UF-1401 produces just over 3100 Lumens in my light box , but begins to sag immediately . The light drops to 2900 Lumens relatively quickly and then stabilizes at just over 2800 Lumens . I can only conclude from this behavior that the sag is directly related to voltage sag under load rather than any sort of heat related sag . ( Batteries are SONY VTC4 )
MEDIUM - 482 Lumens
LOW - 11 Lumens
The light really needs more light levels . I have found around 80 Lumens to be about right for walking in the Suburbs and the gap from HIGH to MEDIUM is just simply too massive as is the gap between LOW and MEDIUM . There really needs to be another light level around 1000 Lumens . The UF-1401 is really begging to be a 5 light level flashlight .
UI or User Interface:
To turn on the light you need to hold down the switch for about 3 seconds . The light always starts in high ! From here a quick press of the button will take you to medium and another press will take you to low . ( High > Medium > Low > High )
Flashy Modes : These are thankfully hidden and what ever light level you are on , just do a quick double click and you will start in SOS . Another double click will take you to strobe . ( SOS > Strobe > SOS ) . A single click will exit you back to your last light level , or if you press and hold the light will turn off .
LED Readout: The UF-1401 is equipped with a LED read out to let you know the state of your batteries , as well the light level your in (?) . Actually the read out to let you know the state of your batteries is very nice . A 9 means 90% or better ( to 100% ) and a 8 means 80% or better ( to 90% ) and 7 means 70% or better ( to 80% ) .
BUILD QUALITY:
On receiving the light I simply could not get it to work . I knew what the problem was , the battery tube was not making contact with the head to complete the circuit . I have some silicone grease handy and after lubing the threads the battery tube screwed on with no issues . The anodizing is nice and even and looks to be well done . Cant complain about the machining and so far there have been no issues of any kind ( except for needing lube on the threads ) . Shaking the light like a rabid monkey there are no funny noises , no battery slop . Build wise it looks like UniqueFire has done a good job .
CONCLUSION:
The build quality on the sample received for review is good , not Nitecore good , but good and yes the threads needed Lube but that's no deal breaker . The light Pumps putting out a relatively stable 2800 Lumens ( in my light box ) with my batteries and it never got more than lukewarm . I guess all that heft is good for absorbing and dissipating the heat generated by 4 emitters . The light is heavy and it should have come with some sort of attachment point so that perhaps a sling could be used . 3 light levels just don't cut it . Ok 11 lumens ( LOW ) is really a good light output for dark places like forests where you perhaps want just enough light to walk bye , but in urban environments you want something around 80 Lumens . Medium is a little too much if you care about other people around you , but I have always liked an output level around 500 Lumens . There has to be something between 465 and 2800+ , it's just to big a gap . And such a powerful flashlight really wants to start from LOW and work it's way up .
The styling is amazing , the UF-1401 really looks the business . I love the flood , it is simply amazing . Did I mention that out to around 150 meters there is just no where to hide . ( Might make for a decent hunting light ) And one need not be afraid to run HIGH for several minutes as the light did not seriously heat up for me when I and my friend ran it for several minutes on high .
Parasitic Drain / YES 0.3mA . ( Just unscrew the battery tube if 0.3mA bothers you )
3 Light Levels ( Needs 2 more light levels - 80 and 1000 Lumens )
Starts on High ( want's to start on LOW )
3 Second start ( Hmmm , a lot of stuff can happen in 3 seconds while you wait )
Heavy ( 635 grams with 4 18650 )
Powerful ( oh yeah ) 2800+ Lumens
Flood ( I do like flood - especially 2800 Lumens of it )
Heat - Takes a while to warm up ( That be good ) , but we are almost at winter . ( So ambient temp is down )
Really want's an attachment point . ( Tripod mount ? )
Is well made when considering the price point .
Looks awesome ... ( If you care about such things )
Hidden flashy modes - Really nice .
No detectable PWM
Now you might look at the UF-1401 and for a moment think that it might make a decent club ! And I would hesitantly agree that defensively ( one hopes ) the UF-1401 might be capable of cracking open a coconut . Well if one was inclined or needed to crack open a coconut . The aluminum bezel is certainly hefty for purpose . It does how ever block a fair amount of light and I just wonder if it can be taken off . ( Just checked ) I does seem to serve a purpose , holding the reflectors and lenses in place .
Do I like the UF-1401 , hmmmm Yes I do . Could it be more , yes it could ! In fact I am going to buy a set of 4 batteries and the UF-1401 is going to become my Bump in the night Light ! My current bump in the night light is the EA8W , but it's just been replaced by the UniqueFire UF-1401 . Seriously , 2800+ lumens that light up the yard like the sun just came up . ( Yeah )
So keeping things is perspective like PRICE . I am going to give the UF-1401 8 out of 10 . I am deducting half point because the light starts @ 2800+ Lumens and half more point for only having 3 light levels . Another half a point for the 3 second start and half a point for the lack of an attachment point . I would like to thank FastTech dot com for sending the UF-1401 for review and as well for the new powerful house light . ( It's going to be so sick lighting up possums @ 2AM as they walk along the fence or something else - hmmm , what about the neighbors ? )
UniqueFire UF-1401 Beams (0 min 33 sec)
Question Charging 3-4 Li-ion 18650 batteries in series boblalux Batteries and Chargers 0 Mar 06, 2016 08:27 AM
Discussion UF F-16 a better flyer than UF Hawk? Googleplex Pusher Prop Jet Models 4 Mar 30, 2008 05:42 AM
Another UF Build Basil Foamies (Kits) 0 Jan 10, 2005 08:25 PM
