This thread is privately moderated by mlilasic, who may elect to delete unwanted replies.
Jun 04, 2018, 05:04 PM
FPV addict
mlilasic's Avatar
Mini-Review
Review of Holybro Kakute F4 AIO V2 - FC STM32 F405 MCU ODS PDB
Review of Holybro Kakute F4 AIO All in One V2 Flight Controller STM32 F405 MCU Integrated PDB OSD for RC Drone
I got this Kakute F4 AIO v2 for my upcoming 6S build because this board supports up to 6S, has built in OSD and PDB (up to 120A), and according to the manual it has 5V, up to 1.5A BEC which should power receiver, FPV cam and VTX (even a high-powered VTX like the Unify Pro), lots of UARTs, buzzer pads, voltage and current sensor.
In short, everything one DIY quad builder would wish from FC and all that in simple and well thought PCB layout with nice price tag.
When I am already mentioning the manual: Congrats Kakute on awesome manual!!! - English Manual is HERE.
Whish more RC electronic components would come with this high level manuals.
For sure, there would be less white smoke flavored PCBs and hours wasted on figuring how to connect or configure boards.
I will be using this 6S compatible components:
  • Kakute F4 AIO v2 - product link
  • BrotherHobby Speed Shield 2207.5 1750KV 2400KV 2700KV 4-6S Brushless Motor for FPV Racing RC Drone - product link
  • CNHL MiniStar 22.2V 1000mAh 6S 100C Lipo Battery XT60 Plug for RC Drone FPV Racing - product link
  • X-Racer Quadrant 2-6S 35A 32Bit BLHeli_32 Dshot1200 ESCs - product link
  • ImmersionRC Tramp HV 5-18V 5.8GHz 1mW to>600mW VTX International Version V2 - product link
The Holybro Kakute F4 AIO All-In-One flight controller makes it easy to build your multirotor. It integrates flight controller (FC), power distribution board (PDB), and on-screen display (OSD) in one. The Kakute F4 AIO V2’s layout makes it easy to wire up the other components of the multirotor while keeping the build neat and tidy.
Description:
  • Brand name: Holybro
  • Item name: F4 AIO V2 Flight Controller
  • MCU: STM32F405RGT6 32-bit processor
  • IMU: ICM20689 (SPI)
  • Barometer: BMP280
  • USB VCP Driver (all UARTs usable simultaneously; USB does not take up a UART)
  • 5 hardware UARTS (UART1, 3, 4, 5, 6)
  • Supports serial receivers (SBUS, iBus, Spektrum, Crossfire) only. PPM and PWM receivers are not supported.
  • 128 Mbit Dataflash chip for Blackbox logging
  • Mounting Holes: Standard 30.5mm square to center of holes
  • Weight: 7g
  • Dimensions: 35x43x7mm (includes USB in height)
Features:
  • Additional UART (UART 4) added to support serial camera communication such as to RunCam Split. Please note this is NOT the same as Betaflight Camera Control feature, which controls the menu of FPV cameras like Swift, Monster, etc.
  • Additional UART (UART 5) added to support ESC telemetry such as from BLHeli_32 and KISS.
  • Through-hole solder pads instead of flat pads for more secure soldering especially for beginners.
  • Barometer sensor on board allows altitude hold mode.
  • I2C pad available for certain external sensors.
  • Supports Betaflight and Cleanflight.
  • Betaflight OSD. Change PIDs, adjust common configuration parameters, and change video transmitter channel and power level, all using your transmitter sticks and goggles.
  • Soft-mounting built in. The IMU (“gyro”) chip on this board is mounted on vibration-isolating foam. This means that there is no need to soft-mount the board itself.
  • New high-performance / low-noise / high sensitivity IMU. ICM20689 with 6-axis gyro and accelerometer. Can run at up to 32 kHz.
  • 2 oz. copper PCB allows up to 120A maximum continuous current.
  • Dedicated bootloader button for easy firmware flashing.
  • Low-profile design fits into even very compact frames.
  • Input voltage 7v to 42v. Power the board directly from the flight pack, up to 6S (on “B+” pad only).
  • Automatic voltage monitoring. No need to run a separate vBat wire for voltage monitoring; the Kakute F4 AIO monitors voltage directly from the battery power lead.
  • Filtered voltage output for clean, noise-free video. On-board regulators output 5v at up to 1.5 amps and 3.3v at up to 200 mA to power peripherals such as receiver, video transmitter, FPV camera, or LED strip.
  • Supports BLHeli pass-through for easy ESC upgrade and configuration.
In th box:
FC
and some spare parts
Grab yours Holybro Kakute F4 AIO V2 FC HERE
Jun 04, 2018, 05:10 PM
FPV addict
mlilasic's Avatar
Quick build log:
the building processes...
Almost finished
And
Oct 02, 2018, 04:01 PM
FPV addict
mlilasic's Avatar
Maiden test flight, VTX works perfect!!!
6S quad ImmersionRC Tramp HV 6-18V 5.8GHz 1mW to 600mW VTX Inter. v2 (4 min 48 sec)
Oct 04, 2018, 06:00 PM
FPV addict
mlilasic's Avatar
BrotherHobby Speed Shield 2207.5 1750KV 6S - Kakute F4 AIO v2 X-Racer Quadrant (4 min 12 sec)
Dec 02, 2018, 04:57 PM
FPV addict
mlilasic's Avatar
pict0005 6s 1100 (5 min 34 sec)
Jan 07, 2019, 04:45 PM
Fan of microElectroRfIT
hello.
Question : where can i but the ribbon cable for the IMU??
thanks.
Jan 10, 2019, 08:59 AM
FPV addict
mlilasic's Avatar
Originally Posted by yo8aiv View Post
hello.
thanks.
Sorry, I don't know.
New Product [Sale $27]HGLRC F4 FLAME - FC/PDB AIO & HGLRC F4 Titan - FC/PDB/4in1 30A ESC AIO D Gains Multirotor Drone Electronics 124 Mar 31, 2019 03:14 AM
New Product Airbot OMNIBUS Fireworks V2 Flight Controller With Onboard Damping Box STM32 F405 MCU jaganfpv Product Announcements 0 Apr 12, 2018 12:19 PM
New Product Holybro Kakute F4 AIO V2 jaganfpv Product Announcements 3 Feb 13, 2018 05:37 AM
Discussion BF3.1.5 Omnibus F4 V2 Flight Controller STM32 F405 MCU Integrated OSD Built-in 5V BEC scousethief Banggood.com 10 Sep 13, 2017 06:21 PM
New Product $25 Omnibus F4 AIO (FC + OSD) clone - Betaflight F4 Flight Controller STM32 F405 MCU lmpuIse Multirotor Drone Electronics 20 May 04, 2017 08:01 AM
