Jun 03, 2018, 01:12 AM
Juergen S.'s Avatar
Vakkuum thermo forming in the easyiest way
Hey guys ,
here you can see a very easy way to yakuum forming foam. The heater is from a electric barbecue and the vakkuum is from a vakuum cleaner.
Depron tiefziehen/ foam vakuum thermo forming (0 min 55 sec)
Jun 03, 2018, 09:30 AM
jumo004's Avatar
… always wondered what your vacuum forming setup looked like !
Very cool … er, warm … !
Thanks for posting !!
Jun 03, 2018, 02:18 PM
yank and bank!!
Thanks for posting that.... makes me want to get some depron!!
Jun 03, 2018, 06:30 PM
Closed Account
Nice setup. Simple and not over engineered, with spring clamps used for guides on the pulling frame. Some folks would probably have unnecessary ball bearing roller guides, etc. Got me thinking since I've been using a heat gun with pull frames for canopies, but I have a small carpet seam heater that would probably work perfectly if used similar to your setup.
Jun 04, 2018, 05:46 PM
Petefoss's Avatar
Doug Walsh wrote a great book about DIY vacuum forming.
https://www.amazon.com/Do-Yourself-V.../dp/B000HEDLHS
Pete
Jun 04, 2018, 10:46 PM
Lori, hey, you're home early
CarreraGTSCS's Avatar
Fantastic Jurgen. Thanks for posting that.
Jun 06, 2018, 01:19 AM
Rudi's Avatar
Hi Jürgen,
I jump in. Thx for posting this video !!
Greetings from austria
Rudi
Jun 09, 2018, 02:05 PM
RNAF's Avatar
Jürgen, this is like looking at an ancient method for vacuum forming, if you compare it to your other videos of your other setup! What material is the frame made of and what are critical things to mind according to you?
Jun 13, 2018, 06:54 AM
chester2240's Avatar
Nice! Simple and effective.
Jul 08, 2018, 10:09 AM
speedy01's Avatar
Jürgen,
How thick is the Depron, and what are your clues as to when it's ready to vac?
Gene K
Jul 10, 2018, 11:56 PM
Juergen S.'s Avatar
Iuse hot wire cutted Depron from 0,1/ 2mm thickness. I push the Depron when i heat it and look at the skin
Jul 11, 2018, 08:24 AM
speedy01's Avatar
So similar to how you judge when plastic is ready for forming ... the Depron sags? I had assumed it would shrink and crack/melt
Thanks for the explanation!
Gene K
Jul 11, 2018, 12:07 PM
Petefoss's Avatar
With plastic films I look for when the sheet tightens back up. Heating it causes wrinkles as it expands but then at forming temperature the sheet tend to shrink due to the stretching "tentering" process after extrusion. But for Depron I suspect that too hot since it's not tentered as far as I know..
Pete
Jul 26, 2018, 02:56 PM
Hi Juergen, your work is stunning. Did you use already a Vector foam from Graupner?
Discussion Thermo forming a micro Spitfire mrexcel Scratchbuilt Indoor and Micro Models 6 Nov 06, 2016 08:01 PM
Discussion Vacuum\Thermo forming Forming using a Plastic Model Kit? MikeBiv The Builders Workshop 0 May 19, 2009 05:46 PM
Thermo formed Depron arf rtherbe Foamies (Kits) 17 Aug 27, 2005 11:51 PM
thermo form depron wings bleriot 11 Scratchbuilt Indoor and Micro Models 3 Aug 11, 2004 04:05 AM
Thermo Forming Foam Mario Scratchbuilt Indoor and Micro Models 5 Nov 27, 2002 11:58 PM
