Sep 02, 2018, 06:34 PM
Remember... Fly for fun!
ALEX HEWSON's Avatar
Ah bugger! At least it's on the flange...
Sep 03, 2018, 08:34 AM
pnc
pnc
pnc's Avatar
I need to get you down here and we can cut some aluminum molds
Sep 24, 2018, 06:27 PM
pnc
pnc
pnc's Avatar
Well after a bunch of redesigning the hinge slot cutter I came up with this ......
Works great!!!
Sep 24, 2018, 06:44 PM
impressive. Post a video of your cutter in action.
Tom f.
Sep 24, 2018, 07:48 PM
A dream will find you
StevenSeim's Avatar
Jealousy meter moved sharply right...
My god that's cool Pete. Well done indeed. Right on.
Sep 24, 2018, 10:16 PM
Rock Breaker
gazasmith's Avatar
Works great!!!
Dremel mounted in alloy bit.
the plastic bit rubs on surface of wing.
The mic sets the depth.
Cool setup I need one.
Sep 25, 2018, 10:18 AM
pnc
pnc
pnc's Avatar
I will make you one Gary
Sep 25, 2018, 10:49 AM
pnc
pnc
pnc's Avatar
Here's the first try
Sep 25, 2018, 11:00 AM
Wow, that is quite a nice setup. But what is the scribed line that goes between the servo openings?
Follow up question: how are you holding hte wing in place on your frame while cutting?
Tom f.
Sep 25, 2018, 11:16 AM
pnc
pnc
pnc's Avatar
That is a scrap Wing that I laid up a while back so I'm just cutting just to cut I'm holding the wing in place with vacuum I'll show you a pic.
After you vacuum the wing down you can adjust it this way then just snuggled down with the Wingnuts
Sep 25, 2018, 11:20 AM
pnc
pnc
pnc's Avatar
I have been getting all the tools I need ready to do a production run of the FPS so they're all consistent so I built this hinge cutting machine
Sep 25, 2018, 11:25 AM
Loving Lee's Slope Slut
JarheadFlyer's Avatar
Great bit of engineering there Pete! Nicely done
Sep 25, 2018, 11:35 AM
pnc
pnc
pnc's Avatar
I ran out of Teflon so I tried machine and a chunk of uhmw for the guide I need to get an End Mill to cut the slots I was cutting it with a drill bit going really slow after drilling a bunch of holes worked okay and the Teflon but not the uhmw this part is taller and the slots are longer so I can cut a shallower slot. Another piece of scrap uhmw
Thanks Tom for the compliment
Sep 25, 2018, 11:51 AM
pnc
pnc
pnc's Avatar
Thanks Aaron
Sep 25, 2018, 04:04 PM
pnc
pnc
pnc's Avatar
Here we go I picked up an End Mill so I could cut the slots and made it out of Delrin AF and lengthen the slots so you can cut none or a bunch
Discussion light 60 inch sloper molded similar to Climax Pro vigli Slope 26 Nov 08, 2011 04:20 PM
Discussion best 60 foamie for ds and frontside grfcon Dynamic Soaring 32 Dec 09, 2008 12:34 PM
Discussion Tailless airfoil? DS machine?frontside sloper? theclaw Slope 5 Sep 02, 2006 10:50 AM
