Aug 25, 2019, 01:39 PM
Lithium Member
Herb's Avatar
Which one did you get ? Frecce Tricolori ?
Post some pictures will you
Aug 25, 2019, 01:41 PM
2019 EDF Jet Jam June 13-16
Robert Belluomini's Avatar
Yes, Frecce Tricolori, I will post fotos of my build soon.
Aug 26, 2019, 06:32 AM
Turbine
K-45G3 on its way. Iím in Europe this week, hope to get on it with some pics after 9/1
Ordered Grumania pipe for Hawk, Iíll compare to stock Sebart. I hope it squeezes in there
Aug 26, 2019, 08:10 AM
Patmac there is a very good pipe builder in the states. Jettechusa.com
Aug 26, 2019, 12:19 PM
To fit a Grumania pipe, I think the Hawk is easiest out of the 3 air frames, the L39 is most difficult.
The quality of the pipe is good just donít like to attach a big bowl at the front.
Suggest you to test run your G3 on a test stand first and donít use diesel on this engine.
Aug 26, 2019, 09:31 PM
A bit more work done this evening.
Removed the blind nuts that come installed for the JP Fan and centered the DS51 and drilled the holes after determining the fore/aft position to allow the bellmouth to fit correctly.
Made a ESC mount and glued it in place.
I cut the center out to allow cooling holes in the base plywood should it be required.
Aug 27, 2019, 06:57 AM
Mb
Here’s my mini Mb339 with shubie. You’re right, pipe was impossible!
Thanks RB for pipe recommendation, they look pretty great. I’m big on Carlos tanks, his tanks are super nice.
I’m still away, but I’ll do a few comparisons on hawk, hopefully next week.....
Aug 27, 2019, 08:19 AM
What a pretty jet patmac. I see you got your setup from Gary, Interesting he installs a heat sink.
The motor tube stator design cools the motor quite nicely WITHOUT an additional heat sink.
What cell count are you going with?
Aug 27, 2019, 08:40 AM
Team Futaba
Neilbo4's Avatar
Looking great guys!
Still have a couple Hawks and MB339's left for anyone interested.
Neil
www.sebartusa.com
[email protected]
Aug 27, 2019, 09:48 AM
Fans
Garyís fans are GREAT- I have several
I fly mine on Revo LIHV 11 and 12S, 4400ís
Started with 10, flies great on my mini Avanti
Iím excited to try the K-45G3 in either the Hawk, or Avanti
Aug 27, 2019, 05:23 PM
Fan mounting tip
When mounting the DS51 i use a #3 servo mounting screw with a #2 fender washer and then a cut a length of 1/2A silicone fuel tubing over the screw. It fits perfectly into the Grommet in the mounting flange. I tighten the screw until it the washer contacts the grommet and then go a 1/4 turn more. Makes for a very quiet fan installation!
Aug 27, 2019, 06:44 PM
Quest for Speed!!!
Mike_eee's Avatar
Jet fan 90 : 12 s
I have a spare jet fan 90mm 12 s power system , will any of these sebart planes take this set up or is sit too heavy for 12s 4500`5000 mah?
Mike RC
Aug 28, 2019, 03:02 AM
Flying Fiz's Avatar
I'm going with the KingTech K45 G3 as well in this jet, my first turbine. I was able to source a pipe from Grumania for a Sebart Mini MB339. It is designed for this model. I just purchased one. Hopefully that will be an easy fit, or even if it's designed for the model are you saying that its hard to get in there?
Cheers
Phil
Aug 28, 2019, 05:01 AM
Mike RC
Im using a 12S 5000 setup in my MB339
Aug 28, 2019, 05:11 AM
Jet fan
Mike RC
I have jet fan 90ís in an Avanti and L-39 from Sebart. They fit/fly great on 10-12S
Cool New HET L-39 90mm by EJF.com AceMigKiller Electric Ducted Fan Jet Talk 715 Feb 28, 2018 08:28 PM
Build Log HET L-39 Albatros 90mm 8S build metalfred Electric Ducted Fan Jet Talk 71 May 23, 2016 04:10 PM
Build Log HET 90mm Composite L-39 By Turbo Fan Electrics ~~VIDEO ADDED~~ TurboFanElectric Electric Ducted Fan Jet Talk 52 Sep 11, 2011 09:24 AM
