H-King Desert Fox 1/10 Scale RC Truck
Hobby King has a new version of their 1/10th scale basher, the Desert Fox. They've crammed more power into the truck with a new motor and ESC and given it more run time with a higher capacity battery pack.
New and Improved Desert Fox Truck
Hobby King has a new version of their 1/10th scale basher, the Desert Fox. They've crammed more power into the truck with a new motor and ESC and given it more run time with a higher capacity battery pack. It's also waterproof so you can play even when it's wet out. It keeps most of the same mechanics as the previous model and it has some cool features like a light bar that you can install 5mm LEDs to make it functional. To get inside the truck, you pull two pins at the front and the top of the truck lifts up on a pivot point at the rear. This gives you easy access to the battery bay and other electronics should you need to work on anything.
The Desert Fox has been a really popular truck for the H-King brand and these revisions will only help that to continue. Pricing on the RTR version comes in at only $145.
Check out the H-King Desert Fox 1/10 Scale RC Truck Here
Features:
  • Just add a battery and you're ready to roll
  • Shaft driven 4WD with a center slipper clutch
  • Adjustable oil fill shocks
  • "Real" spare tires included
  • 5 useable light (5mm LEDs not included)
  • Easy access battery design
  • Aluminum chassis and top plate
Specifications:
  • Length: 530mm
  • Width: 290mm
  • Height: 180mm
  • Wheelbase: 325mm
  • Gear Ratio: 8.3:1
  • Tire size: 95x40mm
  • Hex Hub Size: 12mm
  • Battery Tray Dimensions: 142x46x24mm (MAX battery size)
  • Motor: 3652 3250kV Hobbywing Brushless
  • ESC: 50A Hobbywing Brushless ESC with XT60 Connector
Jun 02, 2018, 07:25 AM
Fan of just about anything RC
SoloProFan's Avatar
Looks nice, hope it doesn't have some blatant weak spot, like we've seen on some HK cars.
Latest blog entry: For the love of the hobby!
New Product H.King "Desert Fox" 1/10 4WD Desert Racer Jym73 Off-road Cars 421 Apr 16, 2019 07:59 AM
Discussion Iron Track Dirt Whip Truck 1:10 Scale 4WD Electric Desert Truck Ready to Run (Red) RC Nitro_Nancy NitroRCX 0 Apr 09, 2018 03:23 PM
New Product XLH 9120 1/12 2.4G 38km/h Desert Off-Road RC Car Racing Truck Car Best Gift For Grow BG Tobey Off-road Cars 76 Oct 26, 2017 05:52 AM
New Product Iron Track Dirt Whip Truck 1:10 Scale 4WD Electric Desert Truck Ready to Run (Red) RC RaidenCharlie NitroRCX 0 Jan 03, 2017 07:12 PM
