May 30, 2018, 07:30 AM
Tragic case
davidleitch's Avatar
Dual powerlab 8 touch - software bg
The powelqb 8 is advertised as allowing 1-8s LiFe4 packs to be charged balanced or unbalanced. Or thatís what I believe.
However as soon as you choose more than 2s the balanced/unbalanced checkbox is grayed out same as it is for lipo or hv lipo.
This means the charger cannot be used to charge any of the many larger. 12v LiFe4 packs that are sold into say the motorcycle or motorboat or RV markets. I use these batteries as my field power source.
Can some one please confirm if in fact you are supposed to be able to charge say a 12v 4S LiFe4 unbalanced using this charger? And if so can the software bug be fixed? It should be an easy job.
At the moment I have to use my old cell pro charger which will happily charge. 4S a123 pack unbalanced.
Jun 06, 2018, 10:00 AM
Sindland MC SAA
Howard Matos's Avatar
Good Day,
The PL8 and DPL8T are two different chargers and the specifications are different. Please read the specifications for your exact charger. The DPL8T only supports balance charging using the main discharge leads in conjunction with the balance connector.
New Product Revolectrix PowerLab Touch Series - Dual PowerLab 6 Touch Bajora AMA Media and Publications 4 Jan 09, 2019 01:32 AM
Discussion Torn between PowerLab 8, Dual PowerLab, and iCharger 4010 CC268 Batteries and Chargers 88 Aug 17, 2018 11:36 AM
Discussion Dual PowerLab 8 touch two different power supplies Steber1981 Revolectrix 3 Feb 14, 2018 10:49 AM
Discussion Dual PowerLab 8 Stock Reduction Blowout Jamie Marks Revolectrix 0 Jun 21, 2017 12:28 PM
Discussion Dual PowerLab 8 for Lead Acid and Deep cycle? busarider29 Batteries and Chargers 1 Mar 09, 2016 05:35 PM
