This thread is privately moderated by Jack Crossfire, who may elect to delete unwanted replies.
May 29, 2018, 10:00 PM
Jack Crossfire's Avatar
Refrigerated transportation
Finally cracked open the ice budget & attempted the 1st refrigerated transportation. This requires going both ways with ice blocks, significantly reducing range. 2 ice blocks were quite heavy, but it didn't show a significant increase in tire wear after 10.7 miles. Power consumption increased to 328mAh/mile. The weather started hot & got cold by the end. Sandwiched the salad between the ice blocks. The top ice block finished more melted than the bottom. The salad arrived still cold, which isn't very conclusive unless another test is done without ice, in the same weather. Ice cream definitely needs to be tested.
Whether ice on top or ice on the bottom is more effective is unclear. Most heat should get in from under the robot, but cold should travel down.
Discussion Transporting your multirotor and gear BobbyC1 Multirotor Drone Talk 6 Nov 01, 2016 02:06 PM
News Department of Transportation Drone Registration Jason Cole Model Aircraft & Drone Advocacy 3678 Apr 25, 2016 05:56 PM
Build Log Super Sonic Transport (1964) for YOBBO ozrs Vintage & Old-Timer Designs 74 Apr 01, 2016 03:24 AM
Help! Wing joining design for backpack transport? rcta15 Flying Wings 3 Oct 13, 2015 09:04 AM
Idea Plane Transport Shoetec Electric Plane Talk 2 Oct 12, 2015 08:20 PM
