This thread is privately moderated by biglombo, who may elect to delete unwanted replies.
May 29, 2018, 06:37 AM
biglombo's Avatar
Mini-Review
Airbot Omnibus Fireworks V2 - Flash review with pinmap | GUIDE - HOW TO | FPV
Airbot Omnibus Fireworks V2 - Flash review with pinmap | GUIDE - HOW TO | FPV (4 min 16 sec)
This is a mini photo review of the last AIRBOT flight controller: the FIREWORKS V2! You can find here the main characteristics of the flight controller, detailed pad photo with description and a complete view of the resources and a pinmap of the board.
The Omnibus Fireworks flight controller uses the ICM20608 over SPI for the best possible flight performance. With onboard damping box, the ICM20608 runs perfectly under 32k Gyro loop. If you haven't already seen it, you should check out Josh's awesome video on different IMUs. Also onboard are a barometer and AB7456 OSD chip for the BetaFlight integrated OSD.
If you want to purchase please follow this link (not affiliate): https://store.myairbot.com/flight-co...reworksv2.html
If you want to download the manual click on this link: https://store.myairbot.com//media/iv...reworks_V2.pdf
Omnibus Fireworks supports 3-6s LIPO direct input, build in hall Current Sensor and Power Filter too.
The on Board PDB is tweaked by using 12-Layer PCB design. There is only 0.2-0.5 mohm internal resistance from input to each output pads
Modifications on v2:
Tantalum Capacitors can be added to the board (not included) Solder pads added for SmartAudio and Camera Control (next to Video pads) The orientation of IMU FPC optimized Gyro ribbon cable redesigned to fit without extending outside the board Added an 8v BEC and LC Filter for the camera and VTX power This board now has 5 UART ports Features:
STM32 F405 MCU, Runs Betaflight firmware(supported from v3.2) ICM20608 Over SPI Bus in damping box. (optional MPU6000) 30.5x30.5mm Mounting holes Supports Lipo direct plugin (3-6S) Supports 5V 1A BEC output (Buck) Supports 8V 1A BEC with LC filter output for the camera and VTX(Buck) STM32 controls OSD chip over SPI in DMA mode (Betaflight OSD) Built-in hall Current Sensor Built-in Professional Level PDB More caps to reduce power noise.
Feel free to ask if you have any question. Building video and test flight coming soon. Stay tuned!!!
New Product OMNIBUS Fireworks v2 from Airbot myairbot.com Multirotor Drone Electronics 390 Jun 28, 2019 03:49 AM
New Product Airbot OMNIBUS Fireworks V2 Flight Controller With Onboard Damping Box STM32 F405 MCU jaganfpv Product Announcements 0 Apr 12, 2018 12:19 PM
Mini-HowTo Step by step guide for Flashing Turnigy 400W v2 with Open-Source Firmware RadMulRot Batteries and Chargers 11 Feb 21, 2018 02:42 AM
