Jun 01, 2019, 10:31 AM
Time For Me To Fly!
fastmax's Avatar
There are some upgrades you can do such as run a hotter motor, or do a complete brushless conversion. Just be aware that the hull itself will have its limitations, and if over powered performance will start to suffer.
Jun 14, 2019, 05:45 PM
malta1's Avatar
Thanks, i'm actually using it as a rescue boat. Actually it can tow in a larger boat pretty well.
Jun 14, 2019, 06:51 PM
Just Plane Nutts
AirDOGGe's Avatar
Possibly the best use for it. I bought a bigger Fei Lun FT009 for the same reason.
If you want to try brushless, a good 2440 inrunner in the 3000-4000KV range would push it along nicely. A 2030 might be better weight-wise, but it's hard to find one 4000KV or lower.
2440 3900KV here: https://www.ebay.com/itm/SURPASS-Wat...PAITZGEM6vEzNA
2440 3000KV: https://www.ebay.com/itm/MOTORE-CLAS...kAAOSwpKtc~kQe
2440 4000KV: https://www.ebay.com/itm/Racerstar-2...oqMsDAZU1TK0Ww
Avoid outrunners, as this little hull will handle poorly with one due to the gyro and torque-roll issues.
Jun 15, 2019, 01:05 PM
malta1's Avatar
Good to know, once the little guy starts getting tired I will upgrade it to brushless. Would any other electronics/parts have to be changed with the motor swap or can I just drop it in?
JJRC Rescue boat!
RC Rescue Boat test with Fishing Line tow (3 min 38 sec)
Jun 16, 2019, 01:34 AM
Just Plane Nutts
AirDOGGe's Avatar
No such thing as a "drop-in" brushless motor to replace a brushed one.
A brushless speed controller (ESC) will be needed, and if the stock speed controller shares a circuit board with the radio, then a new $30-$35 TX and RX will be needed too.
Jun 16, 2019, 06:24 AM
A brushed motor is a complete item, you apply power, it works.
A brushless motor is effectively only half a motor. It needs the correct ESC to do the job of distributing power to the coils that the brushes and commutator do in a brushed motor. So it becomes a case of new motor plus new ESC.
And if the old ESC was built into the receiver card rather than plugged in, a new receiver as well. And if the new receiver is not compatible with the existing one, a new one of them. "Great aches from little toe-corns spring"
New Product Eachine RatingKing F14 Real Time FPV Buggy With Camera 1/14 4x4 RTR RC Car -FREE TEST BG Tobey Car Talk 113 Jun 19, 2018 01:30 AM
Video Skytech (TKKJ) H106 2.4GHz, 2Ch, Mini RC Boat with Water-Cooling system + AKK A1-OSD hermit81 Micro and Sub-Micro Boats 1 May 14, 2018 03:22 PM
Help! Two 3s 2200mah or two 3300mah battery parallel with one 40amp esc will it work? lov2flywarbird Batteries and Chargers 6 Jun 10, 2016 02:18 PM
Charging 6 cell 7.2v/600mah battery with Triton almies Batteries and Chargers 8 Jan 17, 2004 02:04 PM
