This thread is privately moderated by nagas, who may elect to delete unwanted replies.
May 24, 2018, 02:21 PM
My name is Naga
nagas's Avatar
Phoenix User Built Models: Blohm & Voss P.215 (1945)
History
The P.215 was an advanced jet night fighter project by Blohm & Voss during WWII. With a crew of three including the pilot, a navigator and radar/radio operator/rear gunner, it would have been powered by twin Heinkel HeS 011 jet engines set low to the rear, had a tailless swept-wing layout and heavy armament. An order for three prototypes was received in 1945 just weeks before the war ended before any significant detail design work could be begun.
Highly advanced, it would have featured a comprehensive all-weather radio navigation suite and the advanced FuG 244 target acquisition and gun-laying radar.
The P.215 featured a main wing of constant chord and moderate sweep, with small landing flaps forming rear root fillets. Stub tailbooms at the wing tips supported tapered outboard tail surfaces. The horizontal stabilisers and attached elevators were angled downwards both in incidence and, more sharply, in anhedral. The neutral or negative angle of incidence provided longitudinal stability and, in conjunction with the anhedral, contributed to directional stability. Small vertical fins added to the directional stability and supported rudders.
Several armament options were proposed, with the main armament clustered around the nose intake and comprising a mix of heavy 30 mm or cannon with or without rockets. An unusual feature was a further pair of 30 mm cannon set either side of the rear fuselage and pivoting more than 90 to fire either rearwards or upwards. Provision was also made behind the cockpit for a single rearward-facing 20 mm gun with up to 50 elevation, and for two 500 kg bombs beneath the fuselage.
This aircraft would have been formidable with a prospective speed of 860 km/h (534 mph) at 6,000m, a range of 2,200 km (1,367 miles) and a service ceiling of 11,000 m (36,000 ft)!
The Phoenix Model.
Derived from a SketchUp model by Matias G.
you can download the model here.
Build Log Blohm & Voss P.215 another Luft '46 design pmullen503 Foamies (Scratchbuilt) 59 Jun 29, 2017 07:08 PM
Discussion Blohm and Voss 215 flyboyken Scratchbuilt EDFs 30 Dec 29, 2011 02:41 AM
Discussion blohm and voss bv 215 [email protected] Electric Warbirds 5 Sep 27, 2009 11:50 AM
Build Log Blohm and Voss BV P.215 EricClark Electric Warbirds 18 Dec 09, 2007 09:15 PM
Blohm & Voss P.215 anyone? YARDC Electric Ducted Fan Jet Talk 27 Nov 09, 2001 02:45 PM
