Jul 19, 2018, 06:10 PM
In the 2nd step, you use a power source - not necessarily a JR female-female cable. We use a LiFe battery here. You can plug power into any of the ports, except the port labeled "B" - that is where the BIND plug goes.
Step one - put the Serial Link/Nano into XDP emulation mode.
Step two - put XtremeLink device into computer programming mode.
Step three - run the XDP software and click on the find FIND DEVICE button. You will see the info about the device and can then make changes to it. MAKE SURE that you save the changes you make!
Jul 24, 2018, 07:03 AM
Thank you Jim. The reason I used a connector between the ports of the receivers is because I thought that this programming communication between the 2 systems, was done through the ports of the receivers. I see that it is done at RF and there are no physical connections required between the 2 systems. So, each of these receivers have a Tx, yes?
I will read about your telemetry.
Got it, everything in your message, thanks.
Jul 24, 2018, 10:23 AM
Yes, all 2.4GHz systems use transceivers for both the transmitters and receivers.
Jul 25, 2018, 09:16 AM
Ha! Thank you Mr. Drew and thanks for all your help here.
Discussion Bypassing RX and powering a servo directly off the battery 22KV Radios 11 Jun 01, 2016 12:35 PM
Discussion Revers Y servo Westwind76 Beginner Training Area (Aircraft-Electric) 15 Apr 19, 2013 03:46 AM
Question XPS (Xtreme Power Systems) batteries. Any good? wollins Batteries and Chargers 76 Apr 22, 2010 01:04 AM
Discussion Xtremely disappointed with xps White Whale Xtreme Power Systems 9 Mar 11, 2008 06:28 PM
Discussion Xtremely Pleased with XPS Howard L Xtreme Power Systems 8 Feb 27, 2008 06:32 PM
