This thread is privately moderated by Corsair2018, who may elect to delete unwanted replies.
May 16, 2018, 08:48 PM
Trader Rating: 13
$150.00 USD
Seller Pays Shipping
Sold
RISE Indorfin 130 Brushless FPV Race Drone RTF 200mW DRONE
LIKE NEW WITH ONLY ONE FLIGHT
Features
Camera: 600 TVL, adjustable to offset the tilt forward of extreme
speeds
VTX Transmitter: 5.8GHz 200mW, 40 channel
Monitor: 5.8GHz 4.3" color monitor
Radio: Rise 2000 2.4GHz hobby transmitter
Receiver: Built-in, compatible with and prelinked to the Rise 2000
transmitter
Motors: Four 4100Kv, 1104 size
Flight Controller: F3 Flight Controller with Betaflight, an open
source flight software that allows pilot to customize their own
flight program, or just pick up and fly
Frame: carbon fiber
Canopy: Removable to save weight, allows receiver to be installed on
top
Battery: 3S, 11.1V 740mAh 20C Onyx LiPo battery
Battery Charger: AC wall type
4-Pin Receiver Extension: Allows the Indorfin to be used with
nearly any other receiver such as Futaba, Tactic, Spektrum and
more, simply plug in your receiver to Indorfin RX port and select
type of receiver in the Betaflight program
Warranty: RISE guarantees this drone to be free from defects in both
material and workmanship at the date of purchase. This warranty
does not cover any component parts damaged by use or modification.
Includes
Assembled INDORFIN FPV Race Drone with 600 TV Camera, 5.8GHz VTX
Transmitter & Monitor, RISE 2000 2.4GHz Radio & Receiver, 3S LiPo
Battery, Charger, four AA Batteries, extra Props,
Prop Guards and Instructions
Specifications
Drone;
Diagonal Size: 5.1" (130mm)
Width: 5.0" (127mm)
Length: 4.3" (108mm)
Height: 1.9" (47mm)
RTF Weight: 5.9 oz (169 g)
Propellers: 2.75" (70mm) 3 blade propeller diameter
Camera;
Resolution: 600TVL
Input Voltage: 3.6-5.5V
Working Current: 550mA (5V) max.
Micro Memory Card Port: Compatible with cards up to 32GB
External Video Quality: 640x480p VGA
Internal Video Quality: 1280x720p
30 fps (when recorded from micro memory card)
Video Format: AVI
Photo Resolution: 2 MP
Receiver/Monitor Specifications:
Monitor: 4.3" (109 mm) color LCD
5.8GHz Receiver: 5 bands (A, B, E, F and R); 40 channels
Antenna: RP-SMA 3dBi whip
Receiver Sensitivity: -90db
Screen Resolution: 480x272
Format: NTSC/PAL (auto-adjust)
Micro Memory Card Port: compatible with cards up to 32GB
Battery: 1S 3.7V 1400mAh LiPo battery
Operating Voltage: 3.6-5.5V
Run Time: 1.5 hours
Comments
FPV 'First Person View' transmission products with output power
greater than 25mW require a HAM license to operate legally in the
USA. This involves a 35-question multiple-choice test and a small
fee. You can contact an amateur radio club in your area for
information or assistance in obtaining a license. Also see the
Amateur Radio Relay Network web page about obtaining a license.
Customers outside of the USA should understand and follow all
telecommunications or other regulations in your area.
Always follow the AMA Safety Code when operating model aircraft.
Visit the Academy of Model Aeronautics and search for FPV 550, and
read "Document 550 - Utilizing First Person View Systems to learn
about the safe operation of FPV 'First Person View" systems in
model aircraft.
DOES NOT INCLUDE GOGGLES
Discussion DYS Shark-Mako 100mm FPV Racing Drone BNF F4 Flight Controller 5.8G 25/200mW VTX BobFromMars Banggood.com 0 Jan 25, 2018 10:36 AM
New Product HGLRC XJB-75 Mini Brushless FPV Racing Drone BNF D Gains Micro Multirotor Drones 162 Aug 09, 2017 03:20 AM
Discussion KingKong 90GT 90mm Mini Brushless FPV Racing Drone - BNF (with Code) _sOnGoKu_ Gearbest.com 0 Mar 09, 2017 09:56 PM
Discussion ALZRC Mr.Q 190 190mm FPV Racing Drone BNF w/ 5.8G 40CH 200mw Transmitter 600 TVL Coms scousethief Banggood.com 0 Dec 14, 2016 06:37 AM
