May 14, 2018, 10:41 AM
Street racer's Avatar
Air door type peripheral fans
Four (or more ) Centrifugal fans similar to those on air doors mounted next to each other. Are there any obvoious reasons why this configuration wouldnt work?
I thought it might be better than using a prop, because the fan in directly above the nozzle, so the air doesnt need to be turned 45 degrees and the air has a shorter way to travel, If Im not mistaken, centrifugal fans are more efficient at moving large amounts of air.
I guess I also might be safer on a full size craft because of the smaller fan, and lower inertia of the fan blades?
May 17, 2018, 07:57 AM
Rapidly aging user
raw89's Avatar
I may be wrong, but I always thought centrifugal fans are better at providing pressurized air rather than high volume. Your design is cool but I fear that the fans would have a hard time moving enough air to keep the cushion area pressurized. Good luck if you try it...
May 18, 2018, 02:07 AM
MHA webmaster
Suspect that it would be rather heavy plus you lose the flexibility that a skirt provides, and how would you seal the corners such that the plenum is maintained whilst still providing a route for the air to enter the fan (or are you assuming that the curtain jets are sufficient to provide a cushion on their own - I would suggest not)?
May 18, 2018, 06:21 PM
@ raw89 ; Thanks . Your're probably right that it's pressure, not volume.
@jpcwebb: thanks, i dunno how heavy it would be. About the breaks in the curtain in the corners, keep in mind this is a "cutout" drawing.
the fans would slightly overlap in the corners, air would come in through an intake on top of the fan.
Description:
May 19, 2018, 09:24 AM
A few thoughts based on nothing more than my intuition:
You'll struggle to maintain an even jet distribution along the length of each fan section. Centrifugal fans are typically very shallow, these are deep cylinders. I could see the middle of each section struggling to get any airflow from the intakes at the ends. You might end up with a strong jet right at the intakes and basically nothing further along. This could be remedied by having multiple smaller sections with open intakes in between (pretty much what you've shown in the middle there). Then you have to think about maintaining the jet in between those sections. Could probably be done with a shaped channel to bridge the gap.
Stabilisation jet? My experience has been that these peripheral jet machines don't work very well without one. Easy to tap off some propwash if you have a central motor/fan, how are you going to do it here?
I can see those long cylindrical fans being a nightmare to get running smoothly. You need to maintain a tight clearance between the blades and the inside of the casing along the entire length. I can just see the whole thing vibrating and grinding itself to pieces. Perhaps with a bearing at each end and a very stiff shaft/case it might work. Here is an example of the sort of thing that happens with an unsupported spinning cylinder.
Still since nobody has tried this we're all just speculating here. Would like to see an attempt even if it's unsuccessful.
May 23, 2018, 03:52 AM
that's what I was thinking. Do you think this would require more or less power than a normal skirtless(peripheral jet) hovercraft?
Discussion Centrifugal Fan VTOL AXI Motor Models VTOLs 106 Nov 29, 2019 10:38 AM
Discussion test results: various squirrel cage and centrifugal fans interestingfello RC Hovercraft 3 Feb 02, 2017 01:37 PM
Discussion Centrifugal fan model dll932 Life, The Universe, and Politics 13 Oct 15, 2016 05:07 AM
Cool Centrifugal fan propulsion balsa or carbon Foamies (Scratchbuilt) 7 Jan 04, 2016 06:14 PM
Discussion Centrifugal fan questions FrankW RC Hovercraft 4 Nov 18, 2015 05:14 AM
