Maybe a term like Gain Expo or Gain Priority would be a good alternative? As mentioned above, Stick Priority is used by others, but that doesn't explain the impact is on the gain and thus control surface response. |
Different question - There was formerly a delay built into the self-level that seemed to make using self-level for a panic function (switching over from rate mode) seem like it took a very long time for a model to achieve level flight. I remember the delay was turned down in the last version or so of the A3S2 firmware, but even after that it still seemed sluggish when compared to something like a SAFE receiver. Does the A3S3 also have the delay? If so, how much? |
It's been a long time since I flew an S2. Hard to say if there's much difference without flying them back-to-back in the same model. I like the way the S3 flies, did you change the algorithms for normal mode?
Terms of words in the manual sometimes get lost in their meaning. I think a quick analogy or examples of each setting exactly the way you describe items above would be most beneficial to all the pilots the way you intended the gyro to perform.
Like Instead of "GAIN DROP" why not use what others use, "STICK PRIORITY"? Maybe a term like Gain Expo or Gain Priority Call what you will. Just define what it does and intended for by examples would be more beneficial IMHO Sometimes we read too much into the words and not really getting their real meaning. That's, why I mention examples, would really help. I think the A3S3 would work a lot better for pilots if they knew more on how to set it up by the settings they were choosing. |
Any chance we can get the Auto RR stick mode back whereby rotation rates could be specified? I really liked the ability to specify how fast a roll rate I wanted.
In fact, if it were EXACTLY like the Super 2 but with the remote connector, it would be perfect. |
Latest blog entry: Making an inexpensive EDF centerburner
![]() The sbus/ppm pass thru is excellent. The servo centre/endpoint setup is good, but the PC software needs attention. I had to guess how to do it because the graphics in the app didn't render properly. |
Don |
Hello HOBBYEAGLE,
Nice to see activity from You here. I was losing hope but now I see some promising future ![]() I have around 10 Super2 and one Super 3. So here is my input for you: - As a lot of users say, the S3 feels a little bit slower to react, people find the controls less direct, compared to the S2. - Also, please help me: with Delta wing, there is a difference between S2 and S3. In the wing selection the drawing shows 3 outputs (2 elevon + 1 rudd) on S3, but only 2 outputs (2 elevons) on S2. Does it mean that the rudder is not controlled there by the gyro? I like the one in the S3 better, just think about a jet plane (I have one and I am about to use an S2 there... but maybe I need the S3?) - at the servo settings, S2 software has a "response rate" setting, while S3 does not. What is replacing this function? Some good things I like in S3: -separate connector -6 modes available at the same time, very useful for flight test and setup ...and the last: please consider selling the field programmer cards separately too. Thanks bm |
330 RPM roll rate doesn't seem too realistic to me. That's faster than the rotors of a Huey or Jet Ranger turn and beyond the ability of your visual system to process.
You're probably right. Though i do think it should be the limitations of the airframe that determine performance, not the electronics choking it.
Thread Tools | |
Similar Threads | |||||
Discussion | HOBBY EAGLE New A3Super3 known as A3S3 questions and answers | Go4it | Electric Plane Talk | 693 | Nov 30, 2019 10:10 PM |
Question | What Hertz set for Hobbyeagle A3-L gyro | JIMA | Radios | 0 | Mar 14, 2017 11:44 AM |
Idea | Hobbyeagle Super A3 Gyro for Tail Sitters | PaulB | VTOLs | 1 | Oct 20, 2016 04:05 PM |
Question | Question, Suggestion, Kudos, Complaint, and Bug! | FourDollaRacing | Site Suggestions / Complaints | 2 | Apr 14, 2016 06:27 PM |
Discussion | Hobbyeagle A3 Pro SE gyro for aircraft | 4stripes | Electric Ducted Fan Jet Talk | 10 | Aug 02, 2015 06:33 PM |
