May 05, 2018, 10:07 PM
Just Plane Nutts
AirDOGGe's Avatar
Volantex Vector PRO 798-2 800mm self-righting boat
Is this new, or did I miss it's release? I see a flood chamberrrrr!
https://www.banggood.com/Volantexrc-...r_warehouse=CN
ESC: 60A
Motor: 3720 1800KV Water-cooled
Servo: 40g waterproof
Metal Propeller
Transmitter: Frequency: 2.4G Surface Radio
This boat does not include the battery.
Recommended Li-Po: 14.8V (4S) 3500mAh-5000mAh 25C-40C
[img]
[/img]
May 05, 2018, 10:14 PM
Just Plane Nutts
AirDOGGe's Avatar
-Delete- duplicate post
May 05, 2018, 10:39 PM
Fast electric boats maybe
Jeffro Bodine's Avatar
Ive never seen that hull either , martain50 or 785boats metioned a flood chamber on one thier posts before about the vector 80.
May 05, 2018, 11:28 PM
RELAX. You'll live longer
785boats's Avatar
That's the one I mentioned Jeff. The Angry Shark.
Same hull & gear as the Vector 80, but with self righting feature.
Pretty good value for an 800mm 4s RTR boat.
May 05, 2018, 11:38 PM
Yes the angry shark thats it , do you have pics of the inside so I can see how the flood chamber is constructed ,I may attempt to do the same to the 70 if possible.
May 05, 2018, 11:49 PM
Panhead5496's Avatar
Dang that looks nice. Wonder how fast it actually is somebody get one lol
Latest blog entry: Life Updates :)
May 06, 2018, 02:32 AM
785boats's Avatar
I'm afraid not mate. I have the Vector 80. Not the Angry Shark. Even though they are the same hull, the layout for the battery may be different to help with the self righting.
I would like to see the inside too,
They don't state what type of radio system they supply either. That would be nice to know too.
May 06, 2018, 02:38 AM
785boats's Avatar
I agree.
The lines & shape of the boat is just glorious to the eye.
I've no doubt that it will hit 80kph.
I run it with a 1500kv motor & it is in the mid 70's. The 1800kv motor should get it up there to the 80's.
May 06, 2018, 03:40 AM
Just Plane Nutts
AirDOGGe's Avatar
It probably comes with the same old generic Volantex 2.4ghz transmitter.
The images look like computer renders, but you can see the real thing. Apparently this boat emerged 7 months ago under the Racent brand. No self-righting footage though:
https://youtu.be/5OYVCmCkPbk?list=PL...ReotaVyXLyhl4R
May 06, 2018, 05:52 AM
I posted about the Angry Shark some time ago on this very forum where we all discussed it when it first appeared, I bought one back then but haven't run it yet. It is indeed the same hull as the Vector 80 but with a separate container type flood chamber ala Barbwire XL type. Hardware is all metal & 4mm flex & 5mm propshaft + 2 blade 40mm metal prop.
May 06, 2018, 08:57 AM
Search Volantex Angry Shark 81cm Mono Self Righter on this forum, I posted this on October 24 - 2017. Some of you saw it then & replied to the thread then. I thought it was just me that had a bad memory, Good news if Banggood are going to stock this boat.
May 06, 2018, 09:11 AM
785boats's Avatar
Yes. I deal a lot with Banggood. Not just for R/C gear but also, anything you can think of.
May 06, 2018, 09:21 AM
The Angry Shark deck @ the rear is different to the computer generated pictures, the pictures show the rear deck as being the same as the Vector 80 with the 2 square recesses behind the hatch. The production hull is flat & level with the hatch, making it easier to tape.
May 06, 2018, 09:28 AM
Yes I also get a lot of precision engineering tools from Banggood, their prices are brilliant compared with the UK. Considering how cheap their engineering tools are they are of pretty good quality & pretty accurate. I am currently waiting on about 5 different orders from then as we speak.
May 06, 2018, 01:40 PM
Just Plane Nutts
AirDOGGe's Avatar
Depends on what you buy. BG also sells worthless crap, so watch for that. I usually avoid their tooling.
Example? How about a set of "high speed steel" drill bits that aren't made of high speed steel?
https://www.banggood.com/50PCS-11_52...r_warehouse=CN
It looked like a great deal until I saw this:
"Hss Drill Bit Set For Wood, Plastic And Aluminum."
They are poorly ground too, some with asymmetrical, off-center tips. Avoid avoid!
These can't even drill soft steel according to complaints from past customers. That means that they are either made of cheap low-carbon steel, or they were never heat-treated/hardened properly. I used HSS tooling almost every day for 16 years in a tool & die shop, and still do at home now. HSS drills certainly can cut through plain unhardened steel, no problemo. Junk.
Discussion Pro Boat Recoil 26 Self-Righting Brushless Deep-V RTR Rafael_Lopez Racing Boats - Electric 741 Feb 08, 2020 10:07 AM
Video Volantex V797-3 (Vector SR48) 2.4GHz, 2Ch, Brushless RC Boat, Water-Cooling (+FPV) hermit81 Racing Boats - Electric 12 Jun 21, 2017 11:49 PM
Discussion Volantex boat sometimes turns sharp right at high speed GravityZ Racing Boats - Electric 18 Dec 12, 2016 11:48 AM
Mini-Review FT01 1 4s race boat! With self righting! JohnVH Racing Boats - Electric 28 Jul 01, 2016 09:58 PM
News Pro Boat React Self-Righting Deep-V Matt Gunn Racing Boats - Electric 3 Apr 03, 2016 10:57 AM
