May 05, 2018, 05:46 PM
Rock Breaker
gazasmith's Avatar
Yippee!
Windfire
SPECS
Windfire 760
Wing Span. 760mm
Fuse Length. TBA
Wing Area. 10.07dm2
Aspect ratio. 9:1
Weight.
Windfire 1200
Wing Span. 1200mm
Fuse Length. 700mm
Wing Area. 15.91dm2
Aspect Ratio 9:1
Weight. 400g plus
Windfire 1500
Wing Span. 1500mm
Fuse Length. 700mm
Wing area. 21.32dm2
Aspect Ratio. 10.5:1
Weight.
Windfire 2000
Wing Span. 2000mm
Fuse Length.. tba
Wing Area. 30.31dm2
Aspect Ratio. 13.2:1
Weight
Windfire 2800
Wing Span 2800mm
Fuse Length. TBA
Wing Area.
Aspect Ratio.
Weight
May 05, 2018, 05:47 PM
Rock Breaker
gazasmith's Avatar
Time Line
2017 started thinking about new plank
15-9-18 Adam Togood fly the first WF2000 DS circles at Mt Borah Manila, around the tree for a top speed of 119mph
May 05, 2018, 05:48 PM
Rock Breaker
gazasmith's Avatar
Name Story
hehe
May 05, 2018, 05:49 PM
Rock Breaker
gazasmith's Avatar
Design Story
this has been a good adventure
ill fill in details later
things happen, people get busy, the need to continue the project pushes you.
a PM is sent.
a reply comes, sweet things will move forward agian.
click a tab, look a bit more at the man you PMed.
think a bit why did i pm this bloke, a feeling, a instinct passed to me whilst enjoying a cleansing ale with a new mate. it is something you can not define, something that just locks into the back of your mind. somehow someway the smallest of things direct you to the correct path. There may be lots of options in front of you, all will get you close to where you want get. Which one. the chose is the right one, which choice is the easiest one and which choice is the best one. ladies and gentleman this is where you scrap the crap on paper, you revert to nature. instinct directs you to the correct choice.
the click of a tab, the press of a button, wow yep i got the right man.
more later.....his last comment on emails
so from me More Later
May 05, 2018, 05:50 PM
Rock Breaker
gazasmith's Avatar
Mould Story
The desire to make different size wings got me thinking of the systems that were used when I was toolmaking. in injection moulds we used different inserts to modify parts a little bit, this allowed us to make multiple similar parts from the 1 mould. This I have applied to the wing moulds.
Instead of looking at moulds as 1 piece for each size wing they are split into sections.
Tips Moulds
left and right hand to produce a 600 long tip panel
Centre Panels.
One 300 long to extend wing span to 1500
One 800 long to extend wing span to 2000
Wing Joiner Bar Jig
To set Joiner bar in exact spot, all wing panels should plug together in any combination.
Mould Joining Jigs
1. to join tips panels to make 1200 single piece wing.
2. add joiner bar jig to make 1200 2 piece wing.
3. 300 centre panel fitted between tip panels to make 1500 single piece wing.
4. 300 centre panel and joiner bar jigs fitted between tip panels to make 1500 3 piece wing.
5. 800 centre panel fitted between tip panels to make 2000 single piece wing.
6. 800 centre panel and joiner bar jigs fitted between tip panels to make 2000 3 piece wing.
7. hehehe another option may come.
6 wing options will come out of 4 wing panel moulds.
There will be extra work in machining these moulds and the jigs to the precision required to make sure joins are sweet.
Prototype wings moulds have been machined from mdf. Pics show the different configurations. Should be able to get a few wings out of them to test fly. Was good to do have found a few things in the programs that need changing.
May 05, 2018, 05:51 PM
Rock Breaker
gazasmith's Avatar
dripple
hehe might be some other topic id like to keep at start of thread.
May 05, 2018, 07:19 PM
Gliders ain't drones!
Zenmaniac's Avatar
-= Dave
-- who is excited about the mould story already!
May 05, 2018, 07:21 PM
It's time for me to fly
JimZinVT's Avatar
May 05, 2018, 11:05 PM
Certifiable User
killercando's Avatar
Madness, so many options Somehow the 1500 3 piece has got me excited
How long will the fuse be? Thinking this would pack real sweet
Lee
May 06, 2018, 03:44 AM
Go Gaz
1500 for Manilla please.
Cheers Adam
May 06, 2018, 04:04 AM
1500 3-part shipped to Sweden.
May 06, 2018, 08:08 AM
Rock Breaker
gazasmith's Avatar
Lee
lee you"ll get what i give you. 700mm fuse
yep will be grate for backpack sites.
ive seen your backpack pack im sure it will take more.
think big 2800
adam
you speced out a super light burner in thermals at Manila ill do my best to have a Windfire ready for you.
Lars
sweden needs lots more planks, will chat when birds start coming out of moulds.
May 17, 2018, 06:49 AM
Rock Breaker
gazasmith's Avatar
first wing program turned up today, centre panel
loaded into machine, run first sim and got a error, easy fix.
more checks etc found roughing cycle not as i like, some setting changes coming.
copied part of the finish cycle to another program. added my own coding so now i can manipulate step over amount etc at the machine. the centre panels are parrallel so when you think about it they are 2D with depth, this makes it easy to manipulate straight line finishing. program went from a few thousand lines to a few hundred.
hopefully a full set of programs will turn up tomorrow so i can machine a set of trial moulds in mdf.
May 19, 2018, 12:03 AM
Rock Breaker
gazasmith's Avatar
Mdf test moulds are being machined.
For some reason the left hand tips shrunk, must be a silly glitch somewhere.
Did a code adjustment, left hand tips fixed but now it machined a set of small right hand tips.
Best work out the problem before I go to steel moulds.
Should be able to make a few prototype wings out of these moulds.
May 19, 2018, 11:06 PM
pnc
pnc
pnc's Avatar
Awesome wow you work fast ...............................................NIC E
Pete
