Apr 30, 2018, 03:57 PM
Modeler/ Historian
Stephen Vick's Avatar
Bronco Type XXIII
Just got a Bronco Type XXIII U-boat. I'm in my brainstorming phase prior to this build. I'm thinking 2.5 inch WTC, either pump or snort. Not a lot of bells and whistles, just a good reliable runner.... Oh, and I will scratch build my WTC. Thoughts?
Apr 30, 2018, 07:09 PM
tchalfant's Avatar
I loved my Bronco Type 23, 2.5" WTC would work.
Apr 30, 2018, 07:58 PM
Found this nice photo of a Bronco Type XXIII with a water pump based ballast system on Facebook. As you can see, starting from left to right; water gear pump , water bottle ballast tank, geared drive motor then servos for rudder and dive planes.
May 01, 2018, 10:19 AM
Very nice. I would advise against that large a diameter wtc. No room for foam at the water line and little for weight below. I found that a 3" OD cylinder was stretching it.
May 01, 2018, 10:21 AM
The big conning tower acts like a sail and needs to be counterbalanced.
May 01, 2018, 01:08 PM
Modeler/ Historian
I love the water bottle as ballast tank! My brain is firing up now. I would imagine that the tower would act much like the Sail on a Skipjack class sub. Good stuff guys, keep it coming.
May 01, 2018, 01:34 PM
Question on a water bottle for ballast. Where does the air go when water is being pumped in? I can see this working with a bladder, but for a solid bottle, the air inside has to be moved somewhere. Is it compressed into the WTC itself?
May 01, 2018, 07:24 PM
As the bottle fills with water air is compressed inside the bottle.
May 01, 2018, 08:26 PM
Ah, ok. Thanks for the info.
I'll be watching this thread as I'm looking to build a DIY WTC as well.
May 07, 2018, 11:05 AM
A conversion kit for static RCing of a Bronco Type XXIII submarine is available here:
http://https://maximus-modellbau.de.tl/NEU-d-Typ-XXIII-1-d-35-V-.--2018.htm
May 07, 2018, 11:17 PM
Have you seen tsenecal's 1/72 Moebius USS Sculpin thread. It has a nice water pump/ bag based ballast system https://www.rcgroups.com/forums/show...-%28Sculpin%29
May 07, 2018, 11:18 PM
Did you ever recover her?
May 08, 2018, 06:34 AM
tchalfant's Avatar
No. It is on eternal patrol.
Jun 25, 2019, 12:40 PM
Modeler/ Historian
Iím back to work on the XXIII, had a Type VII and Newport 12 sailboat distract me for a bit. Iím using Maximus Modellbau WTC and the Nautilus Drydocks (Dave Merriman) fittings set. I have the basic hull and tower complete. You can see the bayonet style lock for the aft section The WTC and aft section will slide into the fore section as a complete unit. The tower will be held in place by use of a locking pin and magnets.
Jun 25, 2019, 07:12 PM
Modeler/ Historian
Coming together now. Mounts for the WTC are in the hull , linkages worked out and, access hatches cut and secured. Time for detail work. A bit of putty here, bit of wire there etc... WTC will install when finished hull is in primer.
Build Log Bronco models Type XXIII and home made WTC GJB Submarines 14 Jul 22, 2018 04:16 PM
Build Log Bronco XXIII buildingreport MFR Submarines 50 Mar 12, 2015 02:57 PM
Video Bronco Type XXIII 1/35th scale tchalfant Submarines 7 May 21, 2014 07:03 PM
Question Special Navy Type II vs Type XXIII redboat219 Submarines 3 Jan 26, 2014 01:06 PM
Question Brass Propeller for Bronco's 1/35 Type XXIII redboat219 Submarines 2 Jan 06, 2014 12:53 AM
