Apr 29, 2018, 08:24 AM
Mini-Review
Eachine E58 WIFI FPV Drone with Camera and Altitude Hold Review
Eachine E58 Wifi FPV Drone DJI Mavic Clone Unboxing Review and Test Flight with Phone UFO App (15 min 29 sec)
The Eachine E58 Wifi FPV Drone is a fantastic toy drone for beginners to learn how to fly a drone and shoot aerial footage
with a cheap wifi FPV camera that sends live video feed to your phone with a UFO app that also records the video on the phone and
SD card on the drone itself pictures and recording video on the SD-card on the quadcopter gives better video quality than your phone
the altitude hold function and a 120-degrees camera working good and the transmitter lays good in the hand with nice size gimbals stick
making it an easy drone to fly & shoot aerial videos and learn all the basics with outspending a 1000 dollars and another 1000 on repairs!
Eachine did an outstanding job on setting the rates of the Pitch Roll and Yaw at low and high speed giving that locked in feeling making it fly on rails
and easy to control the wifi FPV drone even on a windy day
So you probably don't crash very often and if you do crash there is a big chance nothing breaks
because of the E58 drone folding arms take the first hit en releases a lot of the G-force that normale break your arms and motors
and there are plenty of cheap spare parts available and easy to rebuild
It's really a great FPV drone and going to be one of my favorites quadcopter of 2018
not only because it looks so good but because of how easy it fly and the good build quality
Most important Specs of the E58
1: a Foldable drone that fits in your Pocket
2: 6 axis gyro for stabilization
3: 720 coreless motors for plenty of power
4: 500Mah 1s lipo battery
5: 2.0MP Camera with 120 Degrees wide angle lens
6: One key takeoff and landing
7: Panic buttons / Killswitch
8: Wifi FPV UFO App
9: Phone control + Extra's functions
10: 100meters Tx range + 30meters wifi FPV range
11: good size radio and gimbal sticks
Eachine E58 Wifi FPV Drone Maintenance Guide With Full Disassembly of DJI Mavic Pro Clone
Eachine E58 Wifi FPV Drone Maintenance Guide With Full Disassembly of DJI Mavic Pro Clone (15 min 12 sec)
To make it super easy for you we made a maintenance guide with an in-depth inspection and full disassemble
of the Eachine E58 going over all the parts and spare parts available and showing you some pre-maintenance tips & tricks
For sale at Banggood
Discount 8% off coupon: toysho
Eachine E58: https://goo.gl/sZrwpb
Spare Props: https://goo.gl/bQ9uKi
Spare Arm & 720 Motor: https://goo.gl/qCE52U
Transmission Gear: https://goo.gl/KC5MCs
Flight Controller: https://goo.gl/moy3CS
Wifi Module and FPV Camera: https://goo.gl/dJ2w7g
Spare Lipo Battery: https://goo.gl/ahQr78
1 to 3 Battery Charger: https://goo.gl/ymesXc
Hard Travel Case: https://goo.gl/PsjhAi
Landing Gear: https://goo.gl/zCzSqd
Top Body/Canopy: https://goo.gl/X6yZiX
Lower Body Part: https://goo.gl/8Mw89e
Eachine e58 tutorial How to fly a drone with your phone
Eachine E58 Tutorial How To Fly a Drone With Your Phone Using Wifi FPV Connect To The UFO App (6 min 12 sec)
Flying the Eachine E58 Drone with your phone opens up a few extra functions you don't have on the transmitter
in this video, we dive deeper into all those extra functions and how to fly a drone with your phone before and test what these functions do for us
Eachine E58 How To Fly Drone With Phone UFO App Test Flight Review
Eachine E58 How To Fly Drone With Phone UFO App Test Flight Review (6 min 27 sec)
Testing the new interesting function of flying the drone on your phone didn't go so well at first
because it's pretty hard to steer the drone with the gimbals on the phone so we switch to the gravity gyro mode
that performed really good and made it much easier to steer the drone pitch and roll
throttle and yaw function still needs to be controlled by the phone gimbal
and the extra waypoint mapping and auto flying on voice command failed and is not recommend to try
you only run the risk to crash and get your drone lost
Eachine E58 Wifi FPV Drone Travel Case Upgrade With Hardshell For Emotion Mavic Clone
Eachine E58 Wifi FPV Drone Travel Case Upgrade With Hardshell For Emotion Mavic Clone (3 min 21 sec)
The E58 Drone is a lot of fun we are taking it with us when we travel and this hard case made it very simple to protect the drone
and carry a few extra battery's and spare parts without worrying about crushing the drone while we take the drone with us it's very handy and recommended if you want to in joy the drone for a very long time
Eachine E58 Drone Range Test How far will it go? and The Wifi FPV
Eachine E58 Drone Range Test How far will it go? and The Wifi FPV (5 min 57 sec)
everyone wanted to know the range of the eachine e58 so we did two test on the range of the drone and a second test to see how far the wifi FPV go's before it stops we performed these test on a nice location in the middle of no where to get the maximum range and clear results to compare with upgrades coming up in the next episode
How Far will it Go? Eachine E58 Drone Wifi FPV Range Booster and Test Flight
How Far will it Go? Eachine E58 Drone Wifi FPV Range Booster and Test Flight (7 min 55 sec)
In the Last Range Test Episode, we didn't like that Wifi FPV already stopped at 60 meters while the drone reached 160meter with no problem at all
and it's around a 100 meters high you want fly to get that beautiful view overlooking the landscape there for we upgraded the E58 drone with a wifi network booster to boost the range of the wifi FPV and the test result are in the video
Eachine E58 How Much Weight Can a Drone Lift/Carry? Test Flight For FPV
Eachine E58 How Much Weight Can a Drone Lift/Carry? Test Flight For FPV (7 min 37 sec)
Some future Range and FPV upgrades we have planned are a bit heavy and there we tested the e58 drone on how much weight it can lift
and carry around without crashing to the ground test result in the video
How To Fly a Drone For Beginners First Tip How To Use Trim Buttons With Eachine E58 Quadcopter
How To Fly a Drone For Beginners First Tip How To Use Trim Buttons With Eachine E58 Quadcopter (4 min 4 sec)
The best tip for a Beginner Drone Pilots that still need to learn fly for the first time is learning how to use the trim buttons
to get the drone take off in a straight line and is enjoyable to fly
itīs also very useful trick when there is a bit of wind pushing the drone away
you can trim the drone to still stay in that one place
5 Tips How To Fly a Quadcopter/Drone For Beginners With Eachine E58 To Learn The Basics Skills
5 Tips How To Fly a Quadcopter/Drone For Beginners With Eachine E58 To Learn The Basics Skills (14 min 9 sec)
The 5 basic skills every drone pilot need to learn before you can fly a drone safely and in any directions, the drone is facing
even the most difficult way when the drone is facing you and all the controls are turned around
plus you get some tips on how to steer the drone with both gimbals at the same time to really improve on your skills
Eachine E58 Drone Runs Out of Battery Crash landed On Ice! Can I Stil Recover it?
Eachine E58 Drone Runs Out of Battery Crash landed On Ice! Can I Stil Recover it? (3 min 51 sec)
A tip on how to rescue your E58 drone after running out of battery and landing in a difficult place to reach
Please watch the video and we Hope these Videos are Helpful to You and You help the Channel
By giving a Like and Subscribe: https://goo.gl/GmzhdD
New Product Eachine E57 WiFi FPV Selfie Drone With 720P HD Camera Auto Foldable Arm Altitude Hold Winintheair Mini Multirotor Drones 5 Oct 24, 2019 06:45 AM
Discussion Eachine E58 WIFI FPV Drone with Camera and altitude hold HowToDIYRc Mini Multirotor Drones 0 Jan 21, 2018 09:26 AM
Mini-Review Eachine E56 Quad - Gravity Sensor - Altitude Hold - 720P Camera - WiFi FPV - Review IndiaHobby Mini Multirotor Drones 4 Dec 01, 2017 06:50 AM
Mini-Review Eachine E53 WiFi FPV Selfie Drone with 0.3MP Camera Foldable Arms Altitude Hold RC Qu siriusflier Mini Multirotor Drones 7 Aug 06, 2017 09:23 AM
