Jul 09, 2019, 09:11 PM
Originally Posted by scousethief
Channel 5 is rates
Channel 6 on a 3 position switch adjusts the ailerons to a slight alternating positive or negative angle.
Channel 8 switches between standard controls and aileron/ rudder mix
Channel 11 is elevator trim.
I've tried reversing every channel up to 20 with no results, simply reversing should turn the gyros on/off
Strange little thing.
That is what I've found too.. channel 6 8 now I'll have to assign channel 11.
Jul 09, 2019, 09:13 PM
Originally Posted by BeastBoi
Has anyone figured out a way to totally disable the auto level?
That is indeed the question everybody would like the answer to!
I feel this model has huge possibilities if it could be flown fully manually. Instead, I find myself flying the WLToys F959 instead, because although it is only 3 channels and therefore far more limited, at least I can fully explore its potential without restrictions being imposed on me by the automation.
Jul 09, 2019, 10:43 PM
old4570's Avatar
It does not ... ( Cant turn off auto level )
3D 6G , both auto level ..
The XK A800 flies a lot better in 3D mode ..
Jul 10, 2019, 10:00 PM
I think so too but I assigned the 3d mode to an easy to use switch on my Jumper and pop it into acro when I feel like doing loops and some yank and banks..
Has anyone set up a Flapperon mix since it has two aileron servos..
that might be handy to use.
Landing in 6G is sure simple.. just point it at you cut the throttle and catch it in you hands..
Jul 10, 2019, 10:26 PM
Can this plane be purchased bind and fly?
Jul 10, 2019, 11:54 PM
old4570's Avatar
Flaperon ?
I think both servos are driven from one channel ..
So how you would split them ?
Jul 11, 2019, 11:40 AM
I kinda have a big problem with this plane
I recently received the xk a800 and the first flight was great. Went out for a second flight and the prop flew off. After I looked at it, I realized that it wasn't the prop that came off, it was the golden piece that friction fits into the motor shaft then screws into the prop/cone. Wanted to know if I just got the unlucky batch or if this has happened to anyone else and how did you fix it? Trying to avoid ordering a new motor as it wouldn't get here in time for an upcoming RC event this weekend. Please help.
Jul 11, 2019, 10:23 PM
You could try putting a piece of thread through the hole in the brass piece then pushing it back onto the shaft, trapping the thread between the shaft and the piece. Use a modelling knife to cut off any excess thread still sticking out. I've used that trick many times for props and even for pinions and it usually works.
Jul 12, 2019, 12:23 AM
Flaperon ?
How is that possible? Seems the would both respond the same but they dont.
Jul 12, 2019, 03:19 AM
old4570's Avatar
Hmmmmmmm , Well !
All channels have been pretty much explored ..
So if they were set up on a different channel ?
So just like any other set up , you can feed two servos into one channel VIA a split er / or in this case a double'r ...( Y harness )
One would need to pull the wing off ..
Either way , both servos function VIA the one channel , whether it is a Y harness or a function of the control board ..
Actually , I have a XK A800 control board ...
Aug 04, 2019, 12:11 PM
Pixelpeter's Avatar
Had a bit of a crash earlier today with my A800. With my A700 out of commission some time ago with a FCB failure, my A800 was now my 'go to' plane for easy flying with a small video-cam onboard. First battery today went okay although I though power went down quite early in the flight. Second battery went just fine, that is till all of a sudden I didn't have any control anymore, except for throttle It was spiraling down and before I knew it, the A800 crashed. Checked again (after powering down) and indeed only throttle control left Looks like the FCB of my A800 kicked the bucket, just like it happened to my A700
Aug 04, 2019, 09:25 PM
Did you try it again with a fully charged battery? If so, you should before you throw it away. Usually if there is a low voltage cutout it will switch off the throttle rather than the servos, but best to be sure. I have a rule of thumb "if there is the slightest possibility a battery could be causing your problem, check that first"! And when I say "battery", I include the connector!
Aug 05, 2019, 05:55 AM
Pixelpeter's Avatar
Just tested it with another, freshly charged battery and still only have throttle control, nothing else.
Aug 06, 2019, 10:40 PM
There goes one theory. At least spares are available, here.
Replacement looks easy, need to remove the wing first though.
Aug 07, 2019, 03:41 AM
Pixelpeter's Avatar
Already have a FCB on its way
Cool XK A600 4CH Brushless "DHC-2" Scale RTF Plane FyreSG Micro Ready-to-Fly 1038 Nov 06, 2019 12:33 PM
Discussion XK X350 4CH 6-Axis 3D dna001 Multirotor Drone Talk 6 Feb 18, 2017 07:05 AM
Mini-Review XK Alien® X250A 2.0MP Camera 5.8G FPV 2.4G 4CH 6-Axis Gyro RC Quadcopter cooperationRC Multirotor Drone Talk 0 Jan 23, 2017 09:52 PM
New Product Wow!! XK STUNT X350 4CH 6-Axis 3D 6G Mode RC Quadcopter samiluo Multirotor Drone Talk 6 Nov 18, 2015 07:21 AM
Video Insane Stunts: RC Quadcopter XK X350 4CH 6-Axis 3D 6G Mode #SamiLuo samiluo Multirotor Drone Talk 0 Aug 27, 2015 08:46 AM
