Apr 27, 2018, 04:33 PM
Exceed RC 1/10 2.4Ghz Short Course Monster Nitro Gas Powered RTR Off Road 4WD Truck C
Exceed RC Nitro Gas Powered Rally Monster Truck Overview/Action (6 min 49 sec)
https://www.nitrorcx.com/51c819-carbonorange-24ghz.html
The heart of the Short Course Monster Nitro truck line has always been a .18 engine with reliable and consistent power for tough off-road driving. With revised porting and crankshaft, internal airflow has been optimized for increased power and torque. With the new design 2.4Ghz remote control pistol transmitter is every RC Car Driver dream to get their hands on a full-range 2.4Ghz system.
RTR 100% factory assembled with installed engine and radio gear makes getting started easy
The 2.5mm lightweight aluminum alloy chassis provides excellent performance and durability
New lightweight suspension arms deliver quick suspension response and reduce the critical sprung weight and overall weight of the car
Oil filled shocks with firm tuned springs keep the wheels on the ground
Complete set of ball bearings for low friction and durability
High capacity fuel tank with perfect caliber makes it impossible to overflow and provides long run times
The Short Course Monster will be available "Ready-To-Run" making it the highest on-road performance 4-wheel drive nitro racing car available to everybody
Completely preassembled with high quality radio gear, painted, trimmed and ready to roll
The new .18 (18 CXP) engine provides reliable and consistent power for high performance on-road driving
Excellent differential system design provides quick access to the front or rear differential by removing only few screws. You can now access the front and rear differential for easy maintenance
Though metal disk brake system provides efficient deceleration and precise control
The Short Course Monster will handle all of your off-road RC car ventures.
Funnel clouds reported forming from these high performance off road buggies!
The high quality 2.4ghz transmitter and receiver work together to let you precisely control your car.
Length:
400 MM
15.7 inch.
Width:
250 MM
9.8 inch.
Height:
160 MM
6.3 inch.
Wheelbase:
275 MM
10.8 inch.
Ground Clearance:
26 MM
1.02 inch.
Diameter Of Wheel:
86*32 MM (F) 86*40 MM (R)
Weight:
1780g
Engine:
18 CXP
